Results 1 to 8 of 8
Thread: Help with after tuning results...
    Tuner RMS-Man's Avatar
    Apr 2004
    Ventura County CA
    88
    '05 Vette 6 speed dynoed last year with only mod being Corsa cat-back.
    100 F ambient temp in dyno room. Bone stock tune.
    Results: 356 RWHP 348 RWTQ
    2 weeks ago I got my first chance at tuning this vette. Using WBO2 in the manifold pre-cat I dialed in the VE, MAF, and kept the stock high octane timing table. AFR runs 12.6 up to 4750 rpm, and 12.8 from 5000 to 5750 rpm, and then 12.6 from 6000 to 6500. All this was done street tuning. Went to same dyno just to get new numbers and was really let down.
    71 F ambient temp in dyno room. Mods 160 Stat, Corsa cat-back and tune.
    Results: 345 RWHP 344 RWTQ
    When I did an overlay of the 2 graphs the tuned graph had 10 more tq and 7 more hp from 4000 to 5500 rpm, but the peak numbers were down.
    Do I need to do more tuning and lean the AFR some more and get more timing in it?
    Should I reload the stock tune make a few dyno pulls and then reload the modified tune and do some pulls to get same day runs for a more accurate before and after?
    Any input will be appreciated. Thanks.
    Joshua
    www.youtube.com/rmsman
    Ventura County area, CA
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    yeah i definitly was about to say load your stock tune for 2 pulls then your modifed tune for the last couple...same day dyno will tell a much better story.
    Apr 2004
    Ventura County CA
    88
    Thanks. I'm going to give that a try next chance I get.
    First numbers were probably a fluke, they seem too high for a mostly stock LS1. Probably another example of Dynojet's overly optimistic temp correction.
    Apr 2004
    Diamondhead, MS
    53
    Its an LS2
    Sounds like you could lean it up some up top.
    Rob
    04 GTO
    Apr 2003
    Almost 2000 feet.
    7,876
    Any KR with the new tune? If so that can hurt you. All the LS2's I've tuned needed some spark reduction to make power. They were all reporting KR in stock form.
    EC
    Always Support Our Troops!
    Yikes I should pay more attention!
    Apr 2004
    Ventura County CA
    88
    EC
    On the street there wasn't any KR, but on the dyno it had about 3 up top so I pulled 3 and reloaded and made more pulls after that and the results were nearly identical.
    I should be able to get the car back this week to tweak on it some more. I'll post what I can find later.
    Thanks everyone.
    Joshua
