Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Ford Trans Tuning Tip - N/V Base
    Quote Originally Posted by Witt View Post
    Make sure "Use VID" is disabled.
    Also make sure the "Use Tire Circ. and "Use Final Ratio" are enabled if available, I think only the trucks use this parameter though.
    I don't have use VID. I've loaded a few different tunes and none have it. Unless I'm looking in the wrong spot? Speedometer section correct?
    Got it. had to turn on advance view.
    Mar 2010
    Texas Hill Country
    3,299
    Enable Tire and Enable Gear
    if setting N/V then 40.3 isn't going to do anything.....try 43 instead.
    Quote Originally Posted by Higgs Boson View Post
    I should be good. i had it on basic and it was hiding the VID toggle.
    thanks for this
  6. #26
    Is there a way to correct the reading off the front ABS sensor if larger wheels are used on 2015 GT?
  7. #27
  8. #28
    Oct 2007
    Crawfordville, FL
    2,409
    Quote Originally Posted by Kcc0521 View Post
    The option to change is in the VCM Scanner , Special Functions
    Eric Brooks
    HP Tuners, LLC
  9. #29
    Jun 2020
    San Diego, CA
    19
    Forgive me for bringing back an old thread, but has anyone successfully changed the N/v Min Learned value? I notice other years of my year truck have a min value of 30 while the most up to date calibration on my truck has a min value of 50. Which is higher than the stock Base N/V value of 40.
