i am just getting started tuning and i beleave i need to tell my ecm that i moved o2 sensors back where on my hp tuner can i find that data that needs changed
I just installed some long tube headers (cat delete) and the sensor wiring on car was too short to connect. But the location of the orginal rear o2 was perfect match. So i swapped the pins in ecm connector front to rear. Not sure if thats how the pros do it....
[email protected]
no I am talking about in the tuning my o2 and fuel trim data seems to keep going rich then lean like its not reading the fuel correction when it is made then it needs to make another correction I have a hp tuner and just want to know what perameters hp calls it
You've installed long tube headers, you no longer can trust or use fuel trims at idle(my opinion, some agree, some don't). There will not be enough pressure or heat to properly make your O2 switch. Open Loop tune the idle, and even OL do not trust your WB, it will also be pretty useless at idle. Your tuning by feel and sound now. The only useful info your going to get for tuning idle is MAP really. With MAP you'll be able to pin point your timing cells at idle and work a nice idle into your tune. Your ass dyno, IMO, is the only way to tune Long Tube headers for idle. The only shot you have at getting a idle that doesn't make your O2s swing too much is to try a higher RPM at idle or run extremely low timing to generate some heat to get the O2's hot and happy if you catch my meaning. IF you search long tube header in this, the Gen 3 forum, or on LS1 Tech tuning section, you'll find plenty to read on this subject. You can trust the RAF table as well. Once you have timing and RPM set, make sure you perform the Base Air Tuning laid out by Russ K. Any adjustment to timing or commanded RPM at idle you must go back and tune this table.
2000 Trans Am WS6
