What could be the cause for this?
Anytime i press "On" for AFR Control the engine dies immediately.
Stock 2002 Camaro Z28 SS.
You could be commanding an AFR that the vehicle can't run with...
We got this guy Not Sure, ...
I left it at the default 14.7 - this is at idle.
Is there anywhere in the VCM Scanner that you can see if the engine is i closed loop?
Should be obvious by looking at fuel trims or O2 voltages. If in closed loop STFT's will at least be moving around a little bit and O2 sensor voltage will be swinging back and forth because of the fuel trims.. i.e. O2 sensor cycling
And what is your setup? What injectors?
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
