Results 1 to 2 of 2
Thread: no speed data from gps available?
    Using AEM AQ1 converted to CSV, I have GPS vehicle speed in my logs but i don't see it nor can i select it within a video.
    Thanks,
    Tony
    HPT Employee Weston@HPTuners's Avatar
    Jul 2014
    39.735034, -103.894459
    868
    I don't have an AQ1 data sample in front of me, but it's possible that it's just not recognizing whatever data column name they used for the speed data. To solve that, you can double-click on your data file in the "Input Files" list, which will open its configuration screen, and then you can make a specific selection for the "Vehicle Speed" setting... If that does not list any suitable speed field from the file, then the "(Calculate MPH)" setting can be used to try to calculate it based on the GPS movement over time.
    If that doesn't do it, then please send a sample of the CSV file to Info@RaceRender.com, and I can get a better idea of what's going on with this file and what we may be able to do to improve upon that...
