I have a 2015 L99, and during power downshifts shifts the motor pulls all of the timing for several seconds and the car just sits there before getting moving. I've tried setting spark min tqmgt to 0 across the board and it helps a little bit, but I don't want to set that too high for fear of stressing the hardware too much. I'm sure there's a reason this timing is getting pulled and I don't want to just brute force a fix.
Here's the data log file with the issue I'm experiencing. https://cloud.cent.betaforce.com/ind...LN2ARHlKTzpcsl
There are four full throttle pulls in this datalog where it occurs, and it seems that the ECU overrides my throttle to 40% halfway through each hard pull that exhibits the issue, at which point power starts coming back. The pulls that exhibit the issue start at 00:07:21.72, 00:08:26.47, 00:11:05.74, and 00:11:23.38.
This only seems to occur when requesting a lot of power while simultaneously changing lanes either left or right. I have not been able to replicate it without the lane change. The pulls in the datalog aside from the four mentioned below didn't exhibit the issue and didn't happen during a lane change. It seems the combination of lane change while requesting a power downshift causes this problem to manifest, which makes me think it might be a mechanical problem, or as Phil from Tampa Tuning suggested, low transmission fluid from the factory. Does that sound like a possibility?
I really appreciate any input you guys may have!
