car never had surge.. replaced lifters and found a vacuum leak on intake I had missed during original install.. fixed leak.. now has surge only on decel .. seems to start at 30mph and goes until 0mph then clears up if car hasn't died by then.. ive tried about every map I can think of in that area with no help.. so if you see something out of place chances are I have tried this and didn't fix it.. lol but any help would be appreciated.. car idles great just sitting in gear and in park
how can I change how much the rich lean swing is during idle and driving.. it does 15.2ish to 14.2ish during normal cruise on wideband.. you can feel car nose over when it swings lean it doesn't do this during ve and maf tuning so im assuming the trims are swinging it too far.. I have done wbltft and wbmaf tuning but maf needs to be done again because of few changes to cold air setup.. but is still close..
car is
6.0 lq4
ls6 intake with truck cable tb and truck mass air
cam is 571 lift 224/228 276/282
headers
