Results 1 to 17 of 17
Thread: wideband for the hp tuners
    what wideband is every body using with the hp tuners logger
    thanks
    Nov 2009
    AUSTRALIA
    104
    Innovate lm-2
    Oct 2011
    QLD, Australia
    436
    Innovate MTX-L Permanantly mounted in the vehicle with External output going into my HP Dongle. I use the LM-2 if playing with a car that isn't mine.
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
    Feb 2010
    Perth Australia
    480
    ^this x 2
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    http://wbo2.com/2y/default.htm with LSU 4.9 sensor.
    *Dirt cheap
    *Narrowband simulation outputting to PCM
    *Calibrated signal to drive custom dash mounted gauge
    *High res output to VCM when tuning.
    *Built in display (good for diagnostic purposes)
    Feb 2010
    Perth Australia
    480
    Has the mosfet driver for the heater element melted the case on your's yet timwds?
    Not yet, I'll keep an eye out.
    It's been hard wired in a daily for 6 months now so looking good
    Jan 2012
    VT
    39
    Folks, surprised no one posted yet. The default "best" WB is considered the NGK AFX, the last version, which now sells as Ballenger AFM500. It's actually made by ECM who manufactures lab grade AFR instruments used in the auto industry. It's functionally before form. You will find many of the respected tuners use them.
    i have bought the lm2
    can any one help me in setting it up and putting the input in to hp tuners as the
    manual does not have any wiring colours for out puts.
    any help when be good
    thanks
    Nov 2009
    AUSTRALIA
    104
    if i remember correctly its the same as the innovate lc-1
    Nov 2009
    AUSTRALIA
    104
    From the centre wiring plug off the Lm-2 is about 14 thin coloured wires.
    You need the lime green one and yellow one to go to the green plug on the side of the HP interface.
    the lime green wire goes in the first slot on the top of the plug and the yellow in the 5th slot.
    once youv done that you need to get it configured to your scanner.
    I have the NGK AFX mounted and an LM1 and I can say the LM1 is much more accurate when compared with the wideband on the DYNO.
    I've tried everything with the AFX from putting great grounds, to grounding to battery and power and still I would start knocking at 11.1:1 AFR which the LM1 shows is in the 12's so I've given up. Tried a different head unit even maybe the sensor is going but being that far off and I'm not getting any errors? I'm using NTK sensor for the AFX maybe I'll buy a new sensor and report back but the LM1 is amazing so I'll stick with Innovate works great and it's cheap.
    Ohh I might have two AFX for sale if anyone is interested the one that's no longer being sold.
    I got it working
    and the lm2 is very fast but i can not get it to read 11.2 and 12.5
    it only reads straight numbers how can i make it read 0.2 it will read 15 at 14.7
    thanks
    May 2017
    Fort Smith, AR
    11
    Been a while, what?s everyone running now? I'm looking at the Bosch lsu 4.2
    Any reviews?
    Feb 2013
    Logan QLD
    54
    Quote Originally Posted by 69judge View Post
    Any reviews?
    im using a innovate LC2 with a LSU4.9. It has been flawless so far.
    Oct 2016
    Poland
    1,744
    Innovate LC-2 because it works trough serial as well so you don't need PRO interface.
    Sep 2019
    Beenleigh
    5
    Quote Originally Posted by 45T-XR View Post
    hi how u going. im new to hp an learning the in an out of it all.. i seen this post about the mtx-l o2 an was just wondering if i would have to get the pro features to get it to work. thanks mat
