Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Hellcat action!
    May 2015
    1,908
    Any concerns on the longevity of the transmission at that level? Believe earlier estimates on torque capability of the A8 is closer to 650 crank tq, you are WAY past that point.
    Jan 2006
    Collinsville IL
    697
    Quote Originally Posted by 06300CSRT8 View Post
    We will see i guess. Seems to be great so far even with no tuning.
    https://www.facebook.com/tuningbyshanehinds
    [email protected]
    2009 G8 GT [email protected] 1.60 - Sold
    2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
    2013 CTSV wagon 9.21@151
    2015 C7Z bolt ons 10.0
    Sep 2011
    Portland, OR
    518
    We put our first Hellcat A8 on the dyno today.
    Our dyno is a Dyno Tech by Dyno Dynamics.
    She is a heartbreaker when it comes to absolute numbers.
    Saw all the same things you guys have. Throttle delay and it will shift at 6200. (Is there a trick to getting it to not upshift?)
    As you know, the HP curve is still heading up.
    544 hp @ 6100.
    so now time to play.
    Couple of questions if you all don't mind.
    I get WB Lambda in the scanner log. Right around .86 Lambda under boost. Can I believe these numbers? That's approx. 12.6:1 AFR.
    We haven't added our own WB to the exhaust.
    You can have the dash display show AFR. When in closed loop, it shows 13.5:1. Sadly, I didn't watch what it said during the pull. Do you guys pay attention to it?
    Fun stuff for a GM tuner to play with.
    Ron
    Y2K C5 A4 Coupe (10.78 @ 127) Cathedral port 6.2
    S476 L33 5.3 69 Nova 8.76 @ 158 Drive to the track street race car
    06 Cobalt SS bought new
    Jan 2006
    Collinsville IL
    697
    Quote Originally Posted by RonSSnova View Post
    544 hp @ 6100.
    Ron
    The one on the dash seems to line out well.
    Mines on meth and pump gas so take that into account.
    Yea as you can see the one was still peaking power.
    [email protected]
    Sep 2011
    Portland, OR
    518
    Agree on the dash AFR reading. If only we could data log that.
    The WB lambda that I am logging show fueling changes, but aren't following commanded.
    We are seeing the heat soak issues.
    Also get better numbers in 5th vs 4th. Converting our numbers to DJ numbers, we are right in line with the 618 seen by others with the stock tune.
  6. #26
    6th is actually your 1:1 gear with the 8HP90, if you don't run into your dyno speed limiter.
    1 2 3 4 5 6 7 8 R
    4.714 3.143 2.106 1.667 1.285 1.000 0.839 0.667 3.300
  7. #27
    Jan 2006
    Collinsville IL
    697
    I run it in 5th. Yea the MD500 will shut down at 200... Learned that with some cars in the past and a recent A6 5.0
    [email protected]
  8. #28
    Sep 2008
    Portersville, Pa
    289
    Quote Originally Posted by 04blackgmc View Post
    You can change the speed limit in the Mustang config file if you want. I don't advise regularly running your dyno above the speed the bearings are rated at but we do alot of LSR cars so we need a little more speed
    RonSSnova - we video's the dash WB reading and used a sniffer in the pipe. We were seeing high 12's and even a few spots at 13 on the dash and the dyno WB logged the same.
  9. #29
    May 2015
    1,908
    12-13 AFR seems awfully lean, what kind of timing are they running?
  10. #30
    Sep 2008
    Portersville, Pa
    289
    Yes it does. I have a remote customer that has been datalogging his AF in a HC Charger and he's getting the same results.
    I have only made dyno pulls and have not tuned or attempted to datalog one yet so I can't tell you what the actual timing is.
    I do have a Hellcat tune file and if I am reading it right it looks like it's calling for roughly 14-17 degrees advance above 4800.
  11. #31
    Aug 2005
    Texas
    115
    Can someone post a stock auto hellcat tune? I have a stock one to tune when it comes in a couple weeks.
  12. #32
    Nov 2015
    4
    I just tune the car and remove the catalytic but the car yesterday turn on the check engine light and the code P2629 appears. P2629-O2 SENSOR 2/1 PUMP CELL CURRENT TRIM CIRCUIT/OPEN
    How I can remove the code without hurting the performance?
    My car had 742 whp and 719 lbs torque in a dyno jet .
