how do i get iac pids on my scaner i have an 02 camaro
You should be able in the Scanner to open the Table Display.
Select an empty (unused) parameter block and 'Insert'.
The popup for Insert PIDs should come up. Select PID List - Engine - and I believe you have to be connected to the PCM to get the IAC Position PID to show up.
Anyone else wanna correct me or help answer?
2001 Z28 (Black-6 Speed converted to 4L60E) - Holley Hi-Ram LS3 Iron 6.0 bored/stroked 408 Forged Internals 11.4:1CR (anticipate 475+RWHP) Moser M9 35-spline Posi Strange center 3.00:1 gears - Best 1/4 Mile: 12.18 @ 113.15 (3360# race weight) when near stock --- No new times yet ---
BMR tubular front L/U a-arms and k-member. UMI Adj. T/A and adjustable rear LCA's, Spohn PHR and Dragbar. !Air!,!P/S!,!TCC/ABS!.
