Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 123
Thread: What did you tune today thread ........
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Thought it might be fun to put up your latest efforts or something new, post up as much detail so people dont need to ask lol
    Did a FGF6 310 ute yesterday 2010 model zf auto
    Mods
    Plaz 800hp kit
    4inch dump ( xforce )
    Cat ( xforce )
    3.5 xforce mild steel system
    38mm port n flap job
    New plugs
    New paper element ( no holes in box )
    New petrol filter
    Went 330rwkw a few times but to lean even tho the customer was mustard for more so settled on 326rwkw at 13psi flat and 12.1 afr
    http://youtu.be/UAAxIVUqKN0
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Jul 2015
    1
    Started playing with the tune on my own car. Didn't blow it up. I'd say it was a good day
    Feb 2013
    519
    Bit of a teazer but not finished yet
    Built everything
    Huge stall
    Big cams
    6466
    Video just doesn't do the sound or aggressiveness justice
    http://youtu.be/QGlLxe_xQCg
    Nov 2009
    AUSTRALIA
    104
    Thumbs up
    Dont know about that. Looked and sounded pretty aggressive to me when i watched it.
    Sounds tuff !
    Aug 2013
    australia
    364
    what a great idea for a thread, I have just got my first dyno and loving it. I will have to put some of our cars we have been tuning up. How do you find tyres and strapping down the car plays an affect in power out put. I just tuned my ve ute and got 353hp and put new tyres on and lost 30hp and that's all I changed.
    Feb 2013
    519
    Yeh mate you will find very quickly that everything can effect readings and you will need to have a method to minimise the effects
    I use a same/same method on every car so i can genuinely see how each vehicle can compare to each other and so on
    Strapping is a big one
    Ramp rates are another
    Wheel diameter next
    Start IAT's are key
    CT is another
    Its why sometimes i can take a while to start a run as i want each run to be as close to the previous so i can see the gain vs input and know its real
    The orange ba sounds great. Are the camshafts worth the headache for the amount of gains? Does it allow you to make more power over 6000rpm?
    Feb 2013
    519
    As many know the camshafts are designed to lift peak power but in these cars I really don't see the need as they do everything best down low and the negative effects don't outweigh the pro's imho
    Each to their own but I never have and never will suggest aftermarket cams for anything under that 600rwkw mark as factory FG gear can support that
    Feb 2010
    Perth Australia
    480
    Op is still an FGT
    04 Velocity MKII M6 & 06 BF F6 555 ZF6
    Feb 2013
    519
    *like
    Sep 2009
    Perth, Australia
    24
    Here's one I did last week.
    BF XR6 turbo sedan, 6 speed zf.
    Mods:
    Process West stage 2 intercooler
    Xspurt 1000cc injectors
    Walbro intank fuel pump
    Venom cat welded into standard exhaust
    New spark plugs AGSP22YE07 0.7 gap
    New genuine coils (old ones cracked)
    Went 305rwkw at 14 psi falling to 12 psi up top and 0.8 Lambda
    Aug 2015
    230
    Quote Originally Posted by zc347 View Post
    Mods:
    What holds something like that back from making more power, will it just ping with more boost?
    Feb 2013
    519
    What are the normal factors that stop a car making power rolly ?
    Aug 2015
    230
    Quote Originally Posted by JETURBO View Post
    I don't really know what the limiting factor is on these cars as it has lots of litres, big flowing turbo, aftermarket intercooler... hence the question.
    Jul 2015
    18
    It cant escape
    Aug 2015
    230
    even with a 4" dump though people seem to get in the ~320rwkw mark. With pump fuel is that around the limit before just get no power increase when adding boost or it starts knocking?
    Feb 2013
    519
    #lukesmate
    An engine works on the same principles as another i wont bother with the basics but we only limited the potential power generation of a falcon if it's either is really poor condition/high kms or a BA
    The rest got tuned like any other car would ........
    My old F6 on 98 with a 4 inch dump
    FG on 98 with a 4 inch dump
    Aug 2015
    230
    Right so people getting less power are most likely a result of the tuner restricting boost as they don't want an old motor going pop on their hands. What boost were those figures on btw?
    ty
    Sep 2009
    Perth, Australia
    24
    The car I posted above was limited by the exhaust and the fact wastegate duty cycle was maxxing out. I've had had quite a few xr6's go 360 - 400rwkw.
    I recently tuned an FG F6 that went 328rwkw with tune only. I did drill extra holes in the airbox. Here's a pic comparing the BF above to the tuned only Fg F6.
    Very similar power everywhere, but the FG has a slightly heavier actuator and slightly better exhaust so the power continues to redline.
    Feb 2013
    519
    Zc347 you will find the actuator will be the issue on the b series as a stock item will struggle to hold +13psi up top
    And a cat only b series exhaust can go 128mph so ~350+
    Like this did
