Results 21 to 40 of 48
Thread: Throttle fluctuation Cherokee SRT Whipple
  1. #21
    May 2015
    1,908
    you need to up your knock sensor voltages especially under 3,600 rpms, its not an exact science but at least 15-20%. I have so much noise with my cam and forged internals around the idle area my 600 and 1000 rpm voltages are the same as my 1800 voltage (100-200% higher than stock). It was false knocking while idling.
  2. #22
    Sep 2012
    Southern Germany
    65
    The Ring lands on MM or Arrington Drop ins are normally good as they are wider than stock stuff.
    do you have an exact AFR reading in acceleration. had it once the accelerator pump stuff had to be risen over 200% to get a proper amount of fuel in there.
    ____DH INDIVIDUAL____
    Hemi & LS Tuning in Europe
    www.dh-individual.com
  3. #23
    May 2015
    1,908
    Yes my comment earlier on the 6.4 was in regards to stock Pistons the 6.4 is worse than the 6.1 as far as ring land thickness. If forged you're golden just need to tweak the knock thresholds.
  4. #24
    Sep 2011
    Germany
    197
    I set the torque/airflow offset like you said but still no difference.
    today is will adjust the knock sensors thresholds properly.
  5. #25
    Sep 2012
    Southern Germany
    65
    Did the changed Vacuum routing of the bypass bring it forward?
  6. #26
    Sep 2011
    Germany
    197
    no, same like before.
  7. #27
    Jun 2016
    19
    have same problem in 2015 whipple jeep srt did you ever fix it?
  8. #28
    May 2016
    1,134
    This is a common tuning issue on non Hellcat boosted Hemi. Not sure but I think there are posts about it. It's definitely fixable in tune unless you have a mechanical issue like bad bypass valve
  9. #29
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by ridenrunwv View Post
    https://forum.hptuners.com/showthrea...-part-throttle
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
  10. #30
    Jun 2016
    19
    Thanks i also have a feeling that the bypass valve is failing
    2015 WHIPPLE JEEP SRT.hpl2015 whipple SRT 2.hpl
  11. #31
    May 2016
    1,134
    I have seen it happen. Light throttle will be really surgy with a bad bypass valve. IAT will be high when off throttle too. I'll check your logs later if I get a chance. Bad bypass valve I see IAT that get very high cruising and cool down under a little load or WOT
  12. #32
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Quote Originally Posted by gmls View Post
    Can you post up your tune file please. I'll take a quick look.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
  13. #33
    Jun 2016
    19
    Quote Originally Posted by Mep_q8 View Post
    sure i would appreciate any help.
    2015 whipple jeep SRT h.hpt
  14. #34
    Mar 2018
    45
    Here are some things to try:
    - Disable Barometric Pressure Fine Tune
    - Increase Throttle Body Airflow in rows <= .5V (Start with 10% and keep adding until surging subsides).
  15. #35
    Jun 2016
    19
    thanks.
    Ill give it a try
  16. #36
    Jun 2016
    19
    OK.
    ITS NOT THE BYPASS I REPLACE IT WITH A NEW FROM WHIPPLE ITS STILL THE SAME.
  17. #37
    Mar 2009
    S. Florida
    582
    OK.
    did you change cams settings.. READ this; https://forum.hptuners.com/showthrea...-part-throttle
  18. #38
    May 2016
    1,134
    Quote Originally Posted by coanan View Post
    That should get you there. I do small airflow and smooth cam timing and don't have surging issues with boost on non Hellcat PCM. Just nice and smooth boost part throttle. I change many other things but think those two are the big ones
  19. #39
    Mar 2009
    S. Florida
    582
    Any updates?
  20. #40
    Jun 2016
    19
    Any updates?
