I've continued to Google. VMP says with a 170* They want 50% at 180 and 100% at 200 http://vmptuning.com/11-50l-cooling/ford-50/
I've been toying with this idea
Code:
% 160 170 180 200 215 223 ?F
24 0 0 50 100 100 100
70 0 0 50 100 100 100
80 0 40 50 100 100 100
90 0 50 60 100 100 100
100 0 55 70 100 100 100
110 0 60 75 100 100 100
?F
Since this is a lower t stat I've adjusted the range accordingly. Maybe the 170 column and values aren't necessary.
Should I changed Desired ECT to lower it from 212? Since I'm lowering the temp of the t stat 20 degrees, take it down to 192-195?
