Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 125
Thread: Have a scenario that requires expertise advise
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    2000 5.3, 2 bar OS, Comp Cam 54-000-11 .605/.610 cam, twin 70mms, when we go to start it with all sensors in place it will fire up the die. If we disconnect the O2's and IAT it will run but very rich (wideband not installed yet). The tune attached is parts copied from another file downloaded to try and help as all we have tried gives the exact same result. Please help and thank you.
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
    Apr 2014
    325
    So we unplug the O2's and IAT and will starts and runs. Plug the O2's back in and runs enough to run the RTT and adjust the VE a little to where it idles and has good throttle response. Plug the IAT back in and the engine dies. Funny little thing that sensor.
    Maybe a log of what's happening? Did you get a DTC when you disconnect the IAT?
    What does IAT read on the scanner when not running, does the temp seem correct?
    1968 Bel Air Wagon
    L92/6L80E
    Apr 2014
    325
    I know it read 85* which I would say is correct. I will run the scanner and log it tonight and check for DTC.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Start by correcting the injector data. Your setup has a vacumn refererenced fuel system which means the fuel pressure increases as Manifold Pressure increases. To this take the values in the IFR and Offset table and copy the 0 kPa value(s) across the entire table.
    Try that first and see if it gets any better. log the startup and idle with RPM, Advance, ECT, IAT, TPS %, TPS V, Commanded AFR (or Lambda if you are using it), Dynamic Airflow, Cylinder airmass (calculated), Idle desired AF, IAC Pos, Startup airflow, LTIT PN, STIT, STFT B1 and STFT B2.
    I would also disable the STFT correction in open loop.
    Ed M
    [email protected]
    Jun 2014
    13
    Maybe you have the same problem I did.. do you have DTC's P0101/0102/0103 enabled?
    http://www.hptuners.com/forum/showth...-Rich-any-help
    86 IROC
    6.0L LQ4 (0411PCM)/T56
    Apr 2014
    325
    Quote Originally Posted by mowton View Post
    So I have setup a config with what you have listed but dont see STIT listed as one of the PID's. Is this a User defined or am I missing it?
    All setup to 0-MIL on first as we are running SD no MAF.
    Ed M
    Apr 2014
    325
    So here is the stock file with the 2bar applied and injector settings as suggested. I did have the STFT's disabled along with the LTFT's. Going to grab the truck to bring here to work on all weekend so hopefully this will be sorted over next couple of days. Thanks and log file should be posted a little later.
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Cyrperformance View Post
    Ok so now you are in open loop (first file was closed loop) and yes in this file the STFT in open loop is disabled but not in the one you first posted....changing alot of things from your initial posting but lets see what happens non the less.
    Ed M
    [email protected]
    Apr 2014
    325
    Sorry, just want a fresh start with stock settings. Changed the STFT to disabled in the other file just in case I go backwards. I didn't get a chance to log it tonight as finishing the exhaust and getting the wideband wired in ran a little late. Will post log tomorrow. Thank you for helping with this.
    Apr 2014
    325
    Here is all I can get with the IAC connected.
    Mar 2007
    Florida
    3,773
    Missing the STIT and 2 Bar MAP PID....
    Something looks out of wack. Have you opened the throttle blade at all yet. Your IAC goes to 310 (max) and idle desired air to 40 g/sec...way too high on both. Turn the setscrew about 1 turn to start.
    Ed M
    [email protected]
    Apr 2014
    325
    Sorry about the MAP, I don't see STIT in the PID list. Am I missing it somewhere? Should be under LTIT correct? Have not touched the screw for throttle but as soon as you step on the gas with the IAC connected it will die. With it disconnected it can rev fine as if nothing is wrong.
    Apr 2014
    325
    No screw for throttle.
    Mar 2007
    Florida
    3,773
    You mean the set screw is missing?
    Ed M
    [email protected]
    Apr 2014
    325
    No there is no provision for set screw.
    Mar 2007
    Florida
    3,773
    STIT s/b under engine>idle and its written "Idle Adapt (STIT)"
    Ed M
    [email protected]
    Mar 2007
    Florida
    3,773
    Its drive by cable setup per tune file System>Platform. Shouls have a setscrew (look underneath) to adjust the throttle blade when redal is released (Closed Throttle)
    Ed M
    [email protected]
    Apr 2014
    325
    Just so everyone knows, there is a screw that the head is on the bottom and tip is covered. Its not that i didn't see it, just I didn't look for it. Sorry about that.
    Apr 2014
    325
    Still running the first file, Just so that we don't get confused.
