Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 125
Thread: Have a scenario that requires expertise advise
  1. #41
    Advanced Tuner Cyrperformance's Avatar
    Apr 2014
    Haines City, Florida
    325
    OKPA, KOEO, bump starter and 50.2KPA
    2006 Escalade LMM Duramax Tuned
    2000 S10 Twin Turbo 6.0L
    56 GMC 100 Status Unknown
  2. #42
    Apr 2014
    325
    0kpa KOEO, bump starter 50.2kpa
  3. #43
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by Cyrperformance View Post
    Put the key to on and start your scanner...thats all. what does the map say?
    [email protected]
  4. #44
    Apr 2014
    325
    0kpa
  5. #45
    Mar 2007
    Florida
    3,773
    thats wrong....you can change the data but assume it will be wrong also. Sounds like a wiring issue. Do you have the stock map sensor you can try using its values?
    [email protected]
  6. #46
    Apr 2014
    325
    With the stock sensor plugged in it reads 50.2, I didn't change any settings just plugged it in.
  7. #47
    Apr 2014
    325
    Guess we will have to push 30lbs of boost to justify this sensor!
  8. #48
    Mar 2007
    Florida
    3,773
    no settings are like 94.43 and 10.33
    [email protected]
  9. #49
    Apr 2014
    325
    So change them load in and re read
  10. #50
    Mar 2007
    Florida
    3,773
    yes
    [email protected]
  11. #51
    Apr 2014
    325
    So added the SAE MAP and it reads 101kpa KOEO no bump.
  12. #52
    Apr 2014
    325
    If that is a three bar map wouldn't I need to go to the three bar OS in order for everything to read correctly?
  13. #53
    Mar 2007
    Florida
    3,773
    That reading is absolutely correct so it says there is somthing going on with that map sensor. It may have said that it needed 10v reference so it may not be compatible with your 5v reference setup. I would try and get the sensor I recommended.
    No, it just only gives you 2 bar of range. The values you put in the MAP sensor tables will align the pcm to the correct map reading.
    You can continue tuning at least in the NA region with the stock 1 bar or figure out what is wrong with the unit/wiring you had in originally. Now you can go back and start the idle tasks over again.
    Ed M
    [email protected]
  14. #54
    Apr 2014
    325
    Explain something quick, With the 366.7 and 33.33 settings loaded in the scanner it shows 105kpa in the SAE MAP but 0 in the 2bar MAP, why?
  15. #55
    Mar 2007
    Florida
    3,773
    When you gave me the 1 bar map sensor reading of 101, was that from the 1 bar or 2 bar map pid?
    Ed M
    [email protected]
  16. #56
    Apr 2014
    325
    SAE MAP PID, which reads 105kpa with the 3bar sensor.
  17. #57
    Apr 2014
    325
    Here is a quick nothing running log with the 3bar sensor in.
  18. #58
    Mar 2007
    Florida
    3,773
    Now I'm confused.....delete the MAP SAE PID and insert the MAP 2 bar. Save the configuration. Now tell me what the 1 bar sensor and 3 bar sensors read with KOEO with their appropriate MAP sensor data in the tune file.
    Ed M
    [email protected]
  19. #59
    Mar 2007
    Florida
    3,773
    I do need to run an errand at this point, sorry.
    Ed M
    [email protected]
  20. #60
    Apr 2014
    325
    Its no problem, I really appreciate the help.
