Z06 Tune in SS Comodorem results
Has anyone in here used the Z06 Timing tables and VE in a VY-VZ Commodore.
If so what results have you seen.
By looking at the Spark tables they look quite good to be used on the SS. Maybe slightly too much timing up around 4400RPM.
TIA
NO Mate haven't, I know it sounds harsh mate but should really dial/tune your original VE Map in properly , I haven't had a look at a Z06 file but are the OS the same?.....VZ LS1 FBW different VE Map to a VY...Have a look in the tune repository for a HSV Tune file and compare the timing map against your original file , in my opinion even the HSV Timing map needs a lot of work to smooth out the dips/troughs...Use the scanner controls mate to tune the timing map also , cheers Bret@ultimatelsxtuning
