Ok, I've added this tidbit of information into the beta email I typically send out so that hopefully makes this perfectly clear to anyone receiving the beta from here on out.
I'm having the same problem with a 2016 Escallade right now that we just finished a blower install on. 2.25 scans, 2.24 is missing most pids like knock retard/ MAF freq, etc. 2.24 also thinks it is a 2013 or 2014. Anyway this truck is AWD so I can't put it on the dyno to record WB data and without EIO working on the street I have no way of recording wideband data. Can we get EIO working in beta ASAP or at least open 2.24 back up to do 2015-2016? I'd be very happy with either. Right now I'm dead in the water.
Can we wait till 2.25 is working with bare minimum to shut down 2.24? Pretty please?
Tuner at PCMofnc.com
I have to tune a 2016 ZO6...I've done a 2015 without issue using the 2.24 scanner. If I understand correctly I cannot do this with the 2.24 scanner as it's a 2016 car...so I cannot log the wideband through my EIO?
Does anybody have a workaround? Wonder if I could put a 2015 ECU in the car, scan and tune, then copy everything into the 2016 ECU...
2023 Durango Hellcat
I have tuned a few of the 2016 Z's. I only use the 2.24 scanner for anything. Just change the "SAE MAP" pid to "high resolution MAP" and it should be fine. They show as 2014 Stingray for me.
www.crawford-racing.com
Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
I'll try that. Thank you.
I wish my solution was that easy. This is a 16 Escalade we just put a blower on.. It's AWD so I really need EIO to record the wideband.
With 2.24
Knock Retard and MAF hz is missing among a lot of others.
With 2.25
no custom pids, no LTFT best I can tell, no EIO logging
The no custom pids really suck because I'll have to average LTFT1, 2, and STFT 1, 2 outside in excel. 4 tables.. uggh.
