Page 4 of 4 FirstFirst 1234
Results 61 to 69 of 69
Thread: 2015 Z06- scanner says it's a 2013- Won't scan most parameters
  1. #61
    28,268
    Ok, I've added this tidbit of information into the beta email I typically send out so that hopefully makes this perfectly clear to anyone receiving the beta from here on out.
  2. #62
    2,742
    I'm having the same problem with a 2016 Escallade right now that we just finished a blower install on. 2.25 scans, 2.24 is missing most pids like knock retard/ MAF freq, etc. 2.24 also thinks it is a 2013 or 2014. Anyway this truck is AWD so I can't put it on the dyno to record WB data and without EIO working on the street I have no way of recording wideband data. Can we get EIO working in beta ASAP or at least open 2.24 back up to do 2015-2016? I'd be very happy with either. Right now I'm dead in the water.
    Can we wait till 2.25 is working with bare minimum to shut down 2.24? Pretty please?
    Tuner at PCMofnc.com
  3. #63
    Sep 2008
    1,668
    I have to tune a 2016 ZO6...I've done a 2015 without issue using the 2.24 scanner. If I understand correctly I cannot do this with the 2.24 scanner as it's a 2016 car...so I cannot log the wideband through my EIO?
    Does anybody have a workaround? Wonder if I could put a 2015 ECU in the car, scan and tune, then copy everything into the 2016 ECU...
    2023 Durango Hellcat
  4. #64
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    I have tuned a few of the 2016 Z's. I only use the 2.24 scanner for anything. Just change the "SAE MAP" pid to "high resolution MAP" and it should be fine. They show as 2014 Stingray for me.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
  5. #65
    Sep 2008
    1,668
    I'll try that. Thank you.
  6. #66
    2,742
    I wish my solution was that easy. This is a 16 Escalade we just put a blower on.. It's AWD so I really need EIO to record the wideband.
    With 2.24
    Knock Retard and MAF hz is missing among a lot of others.
    With 2.25
    no custom pids, no LTFT best I can tell, no EIO logging
    The no custom pids really suck because I'll have to average LTFT1, 2, and STFT 1, 2 outside in excel. 4 tables.. uggh.
  7. #67
    Sep 2008
    1,668
    Quote Originally Posted by veee8 View Post
    Worked great. 2016 scanned just like the 2015 does with 2.24. No issues for me.
  8. #68
    28,268
    With 2.24
    With 2.25
    New beta up with analog inputs added.
  9. #69
    2,742
    Great did you guys add the custom pids also or should I gear up to do this caveman style and average LTFT's and STFT's myself in excel? .... among other math I need on other pids.
