I have a 2013 5.0 with P1 kit.
Problem is i pulled the file from ID and hardly any of the X Ref stuff matches up.
Ill attach the stock file out of the car.OEM.hpt
https://www.facebook.com/tuningbyshanehinds
[email protected]
2009 G8 GT [email protected] 1.60 - Sold
2008 A6 LS3 C6 Cammed [email protected] 1.44 Sold
2013 CTSV wagon 9.21@151
2015 C7Z bolt ons 10.0
The ID data will work very well. The Copperhead uses an inferred injector pressure model and the ID modifier structure works very well with it. Put the data in as presented by ID and you'll be good to go.
Jeff Chambers, Owner
CRT Performance, LLC
349 Cleveland Road
Norwalk, OH 44857
Ph: 419-668-4151
Fx: 419-668-4643
Performance Parts, Service and Dyno Tuning Specialists
[email protected]
you will need to re-normalize it to make it the same. works perfect, used it yesterday on a control pack coyote
Yes...use the data as ID presents it. That WILL require renormalizing.
349 Cleveland Road
Norwalk, OH 44857
Ph: 419-668-4151
Fx: 419-668-4643
Also make sure your tables are in the correct/same units. That gets a lot of people.
Jaime
Do you have this chart?
Figured it all out finally LOL
These fords....
[email protected]
for reference... my base map with ID 1000 injector data
started my car right up and idled great.
Old thread, i copied the injector data into my 5.0 and it had me running 30% rich at idle and a shot in the dark WOT.
