Hi all,
Just wondering if anyone knows how to change the vss source on the pcm. It currently takes it from the abs module but i dont have this as its barra and zf conversion into an older car. I managed to get it started no problem by changing the pats but i need to get a vss source sorted so ill get proper gear changes.
Anyone know if i can change the vss source to hall effect with hp tuners? Maybe some one has a tune file from a bf ute without abs and I can compare the tune with what ive got.
Cheers
