Hey Guys, After installing the new 60 LB/Hr injectors i'm starting to get a rich off throttle condition for a second or two. So I'm assuming that's the transient fueling. Trims are all +-3% so having it go from 14.8 to 13.0-12.5 for a split second is a lot more than just a trim being off. Everything else is running good AFR wise. I'm pretty sure that should be adjusted with the Intake Manifold Volume. I'm just curious as to what way to go. With it taking 3 1/2 min each load + driving I could see it being a 5 hour ordeal haha. I've also heard that the min pulse width can also help, but i'm not sure if that's the overall issue or not. Tune has been posed below as well as a ref.
Truck Info:
2006 F-150, stock everything internal.
GT500 60lb/hr injectors.
Vortech Supercharger.
8-29-15 Dyno.hpt
