Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 115
Thread: Pulling Timing under Boost
    Mar 2010
    Texas Hill Country
    3,299
    I am tuning a 416 with an ECS 1500 and any time I get into boost (over about 110 kpa) it rips all my timing down to -.5 to 1 degree, it releases it back to commanded 12 degrees for a moment, then pulls it all back out again.
    It shows up under Knock Retard, which freaked me out at first, but it's not real knock as best I can tell....any idea of which table I missed? I know, post the tune, I am just away from the tune for a while.
    Max Torque Timing? stock at the moment
    Airmass? increased, thinking of putting it back to stock
    Peak Torque? has been increased
    Driver Demand? throttle doesn't close, has been raised also
    It is also Flex Fuel, running 11% alcohol (pump 93) and no meth....heck, maybe it is real knock. I will pull the plugs when I get back and it's cooled off.
    Feb 2006
    South Carolina
    1,525
    I would consider your injector timing or you may just be too rich.
    Jaime
    Mar 2010
    Texas Hill Country
    3,299
    injector timing is 370, it started out super rich but it's dialed in right at 12:1 now.....still too rich, you think?
    Mar 2010
    Texas Hill Country
    3,299
    here is a scan:spark issue.hpl
    i am expecting this to make around 700 on 93 and as much as my fuel pump will allow on E85...850?
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Higgs Boson View Post
    I don't have any personal experience on the FI LT1s, but many are saying closer to 12.5 range and the Cobalts I know are similar. There is an A&A thread about it somewhere.
    Mar 2010
    Texas Hill Country
    3,299
    i am going to give it a shot at 12.4
    Apr 2007
    1,104
    bring up the max torque timing a bit in that area and see what it does. You may be running into the virtual wall between the two in the sense of urgency.
    93 Ranger. 5.3 D1X. 1069hp.
    Mar 2010
    Texas Hill Country
    3,299
    it is still pulling timing but its smoothing out and getting better as i lean it out. still working on it. after I nail down the afr i will play with max torque timing and spark.
    Mar 2010
    Texas Hill Country
    3,299
    decided to put in some E85, came out to a 55% mix and the low pressure pump ran out of capacity at 3500 RPM. Joe at CPR has a supplemental pump kit I ordered tonight so hopefully I will have it in a week and can resume.
    Aug 2009
    Calibrating
    3,377
    Higgs, what other mods for the fuel system? I assume a Cam/lash cap? How much boost? Your running out of fuel from the In-tank fuel bump?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    lash cap
    Z06 HPFP and Z06 injectors
    commanding 20MPa
    no cam lobe
    416ci @ 12:1
    was running about 16 degrees of timing (E55)
    boost was about 5 psi when it ran out, should be about 10psi at 6500
    in tank pump pressure started going down around 3500 and the high pressure pump followed by about 3800
    the price of ethanol.....i just don't want to use meth. hopefully the pump kit will allow me to run full on E85 when all is said and done. guess I will see in like 2 weeks. for now it's going to have to be just golf....or race gas, hmmm.....
    Aug 2009
    Calibrating
    3,377
    Hmmm how much power you think its making?? What pulleys you running?
    I would assume that setup shouldn't have any problems making 700rwhp on E55
    14 Gen 5 Viper
    Mar 2010
    Texas Hill Country
    3,299
    My goal is 800+ so maybe I will be disappointed......I can always put on a smaller pulley, it has a 3.75 now and is a 10 Rib.
    I can say it pulls as hard or harder than my C5Z with 725/725 (nitrous). Of course, it is hard to tell right now. One thing to note is one of my saved logs shows 68 lb/min at 5800 RPM on 93....so that is promising that I will be over 700 on 93 and hopefully 800 on E85.
    '14 or '15? 15s are a PITA.
    A&A CORVETTE PERFORMANCE
    477 LAMBERT ST
    OXNARD CA 93036
    WWW.AACorvette.com
    A&A CORVETTE SUPERCHARGER SYSTEMS
    SUPERIOR ENGINEERING- SUPERIOR POWER
    SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
    [email protected] 805- 278 4107 Toll Free- 1 888 VETTEPRO
    Mar 2010
    Texas Hill Country
    3,299
    2014. btw, andy, i am going to email you my truck file, bill couldn't match it up with your ticket.
    Mar 2010
    Texas Hill Country
    3,299
    For the guys that have tuned high HP supercharged C7s, how high are you going with start of injection?
    Mar 2010
    Texas Hill Country
    3,299
    Out of Fuel.hpl
    Please review this log when you have a minute. I cannot figure out why it is showing Retard.
    Also, it looks like my low pressure pump is going out around 3500 RPM and the HPFP loses pressure as well as a result (??). So the injectors work overtime to try and keep up.
    Is this what you are seeing?
    Apr 2007
    1,104
    lash cap
    commanding 20MPa
    no cam lobe
    416ci @ 12:1
    do you have a way to log actual pressure like the LNF does? commanded is one thing, actual is another.
    Mar 2010
    Texas Hill Country
    3,299
    Quote Originally Posted by Area47 View Post
    look at the log in Post 17, it is actual.
    Right at or right before 3500 RPMs
    Low Side goes from 60 to in the 40s
    HPFP goes from 19.8 to 6 MPa.
    Injector Duty Cycle goes straight into the mid 40%
    shooting for 12.45 AFR (.85 Lambda)
    Spark is 8-12 depending on what I am commanding, and it starts to pull down to 0 (always shows Knock Retard of 10) I guess as it senses pressure start to go away.
    Apr 2007
    1,104
    i can't look at the log at work. sounds like a fail safe in the background running to try and protect itself from failure. If the timing follows suite with the fuel pressure.
