Results 1 to 3 of 3
Thread: 6R80, Maximum Line Pressure
    Advanced Tuner 96gt4.6's Avatar
    Aug 2008
    Kansas
    489
    I'm poking at tuning the 6R80 in my swap. I've got the shifts pretty firm by upping the line pressure on the shifts, but am curious, does anyone know the MAXIMUM you should run on these transmissions? The box allows up to 500 PSI to be entered, which from the way I'm shifting it now would seem like it has a lot of growing room for holding power on the up shifts.
    I'm currently at 250 psi, stock was 150. I pretty much got it to the point where it barks the tires on the 1-2 and has a solid hit on the 2-3 and 3-4 and stopped. I do plan on adding more power later on, so I'm just curious as to how high the PSI can be set, and not do any internal damage or if possibly you aren't even supposed to command over XX amount of PSI to begin with.
    '17 Whipple'd S550
    Too many other projects to list.....see my YouTube channel for more: https://www.youtube.com/channel/UCr7...-XfDG53sCh6tcw
    Oct 2007
    Crawfordville, FL
    2,412
    Highest I have seen on some of the factory calibrations is 265
    Eric Brooks
    HP Tuners, LLC
    Aug 2008
    Kansas
    489
    Thank you for the information Eric!
    '17 Whipple'd S550
