Results 1 to 3 of 3
Thread: 4l60e shifting issue after swap
    Sep 2015
    31
    Hey Guys and Gals, I'm new to the forum....
    I've got a bit of a mess that came into my shop. I have HP tuners but am by no means expericanced with it, i mostly just write files and log with it.
    So here is what i have.
    71 gmc c-10 2WD
    08 LY5 / 4L60e swap (done at another shop)
    no codes, engine runs good, BUT. the trans shifts 1-2-3-4 imediately upon take off, it will shift maunally thru each gear, but will not downshift at all, does come back down to 1st when stopped.
    I'll attach the file i pulled from the ecm.
    im thoughts are that by the VIN # (from a 4x4) that there is either a 4X4 difference in the TCM tune or that the TCM is not getting written to? the TCM and ECM are not from the same doner to my knowledge.
    So, what i have come up with is to use a known 08 2WD Vin # and get GM dealer to flash tcm/ecm to a stock file and then disable my VATS and cats etc?
    any help would be greatly appreciated
    Thanks, Gerry Foster.
    P.S. please note i didnt not write this tune, i just uploaded it out of the truck....
    Sep 2015
    31
    ended up being a corrupt TCM.
    May 2010
    Behind the wheel
    272
    Thanks for reporting back. I was curious what your fix was. I was going to ask if you had tried disabling the tap shift stuff.
    I had some strange transmission issues once and swapping TCM's then flashing my cal to the new TCM fixed it.
