Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: 6.4 Afternarket Cam VVT Tuning
  1. #21
    Feb 2021
    5
    Yes, with a degree wheel and dial indicater. The card that comes with the cam will have on it somewhere "installed intake centerline" or something like that. You're basicly checking to see if you got everything lined up correctly when you installed the timing set. Search for "checking camshaft centerline" on Youtube.
    2010 Jeep Grand Cherokee / 5.7 Eagle
    CAI - OE AC box, K&N element, SRT8 Air Duct
    Valvetrain - AMS 206/222 .520 lift cam, Non-MDS lifters
    Exhaust - SRT8 manifolds & mid-pipes, Flowmaster 50 Big Block muffler
    Other - 180 T-stat, Catch Can
  2. #22
    Jan 2022
    904
    The cams that are to be installed 'locked' have the dowel in a completely different location than the cams that are to be installed 'limited'
    you dont by any chance have a motor on the stand right now do you FLandy
  3. #23
    Jan 2022
    904
    Quote Originally Posted by Captain052 View Post
    I tried lowering the numbers in the high rpm to gain more hp but i feel the car power drop. Doesnt make sense. Normally retarding the cam should gain hp up top.
    like i just said ^^^ that would depend on where the dowel is
    if the cam is meant to be locked, not limited, it is already retarded a bunch
  4. #24
    Aug 2021
    Yorktown VA
    196
    Well, I for one, am starting to realize that you likely do have to check your centerlines by way of a wheel and an indicator, because I am also starting to think that these centerline values in at least some folk's logs may very well be bogus values for some reason. I'm over here scratching my head a bit because my intake centerline does not match what my cam card specifies. What's got me confused here is that according to my logged centerline and I'm not talking about a degree or two here. I have it figured to be a 9-degree variance between the two... but that being said, I just don't see how this could be right. If this were the case, wouldn't a 9-degree difference in cam position, to say the least, have a negative impact on this build's performance?
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
  5. #25
    Jan 2022
    904
    Quote Originally Posted by Spray-Cam Hell-Ram View Post
    in many areas of the power curve, yes
    the camshaft is the brain of a naturally aspirated reciprocating engine
  6. #26
    Aug 2021
    Yorktown VA
    196
    Exactly. I figured that would be the case as well. Which now makes me fairly certain that these cam positions that our pcms are showing through our scanner logs are likely bogus for whatever reason. Being phaser locked, it never made much sense to me why my exhaust cam position was at 128 to begin with. That would mean that my intake cam centerline is sitting at 102. The closest 5.7L cam grind that I am aware of to having an intake cam centerline that's within even 5-10 degrees of 102 is a Comp Cam with 6 degrees advance ground in and a centerline of 108 I believe.
  7. #27
    Jan 2022
    904
    the main thing until this gets sorted is the 9 degree 6.4 vs 5.7 thing
  8. #28
    Feb 2016
    431
    The PCM will only ever show the stock cam CL numbers.
    The PCM does not know you have changed the cam.
    If it is now fixed (not limited), it will stay at the max advance or lock-pin number.
    This is 128 on 5.7's and 134 on 6.2's, 6.4's.
    You need to translate this number to suit your cam.
    If your new cam is 113LSA +3, this means that at lock-pin (full advance) the intake CL will be 110 (113-3) and
    the exhaust 116 (113+3)....The PCM will still show 128 or 134 tho....
  9. #29
    Jan 2022
    904
    Quote Originally Posted by Hemituna View Post
    Oh yeah, 6 degrees. Not 9. Why are rick n them saying 9?
    Translate it? Where is the cam position sensor reading from anyways?
