Anyone know where I can get the numbers for this throttle body?
2019 Ford Raptor Tow Rig Scarab 195 Open 250HO
2008 Shelby GT500 VMP Gen II-R (17psi), JLT 123mm CAI, Ford SCJ Monoblade Throttle Body, 56# Injectors, BoostAPumps, VMP triple pass heat exchanger (dual fan), 170* thermostat, BBK long tube headers, Dual resonators, Magnaflow Catback, LC2 Wideband, RXT clutch
Wilco. Thanks for the heads up.
Ok so I found these 2 tunes. 1 is from a 5.0 with the Ford CJ throttle body and the 2nd is from a 2013 GT500 with the Ford CJ throttle body. Both have similar numbers in the throttle Throttle body model, however the Effective area X axis is different in both tunes. Identical numbers, different X axis. Which should i use?
File 2013 GT500 with mono.hpt
1405369809.hpt
These are unmodified tables for TBs
Awesome! Thank you!
I tried all the idle parameters in this tune in my 2013 GT500. Idle is great but I did get a check engine light until I enabled Tip in Mgmt. Had been having problems with my idle dropping off, engine almost dying, at start up. Sure glad I found this one! Thanks!
If those don't work, look for the super cobra jet file in repository. Search for Ford Mustang with a 5.0. The file will say it's a super cobra jet.
Don't forget to also enter into the PCM the "ETC Idle Throttle Angle" table values from the Super Cobra Jet.
www.tunedbynishan.com
2018 Mustang GT - 10R80
So what exactly will you adjust to make the monoblade behave? I would just like to be able to quantify what changes are needed for what mods. Doing a compare on a file, I don't know what changes were made just for the new throttlebody.
1. Predicted Throttle Angle(from a CJ File)
2. Effective Area(from a CJ File)
3. ETC Idle Throttle Angle Table(from a CJ File)
4. Increase Intake Manifold Volume(copy from CJ File)
5.
6.
2012 Mustang GT with S/C
4Runner with S/C
Turbo/NOS Hayabusa - 320RWHP
Those 3 will get the car fired up and running without much issue.
You would not want to change your idle airflow tables, unless, you actually needed more/less airflow.
If the car you are tuning is NA with full bolt ons, then those 3 tables should be all you need to run properly.
These 3 tables will tell the PCM the relationship between position and effective area as well as the idle position for idle airflow values.
TXCharlie - I would like the excel file as well, if you could.... Also, do you have the numbers in that spreadsheet for a the 67mm twin TB?
4Runner with S/C
So if I'm putting this back into a 2008 GT500 which does not have the ETC Idle Throttle Angle Table. Is there anyplace in this tune to put this? LOL. Thanks for the help!
...quick reply to the thread. I spoke with VMP about their 67mm TB and they suggested using the SCJ 65mm data. Thanks to txcharlie for posting.
