any known issues scanning that one?
ZL1 Wheels/Tires
And no scanner enhanced PIDS (GM specific PIDs.. no knock... etc).
ZL1 Wheels/Tires
How do you "manually" select an ECM type?
in 2.25 you'd select it in the drop down box at the top. The software will detect the comms type and list all available ecm's that used that type of comms, from there you can select the ecm type.
Full Service GM Late Model Performance Facility
www.redline-motorsports.net
Follow US on FACEBOOK!
Follow us on Instagram! redline_motorsports
My bad on that. Latest release has engine support added.
