Hi all. Been having an issue lately. Tuning VE and MAF was going good till this started happening intermittantly. After a part throttle accel my 02's will flatline in the 900's, trims go way +++++, and my LM-1 shows a steadily richening condition. If I shift into neutral the problem will eventually correct as well shutting down and restarting engine. It only happens at part throttle. I reset my VE table to stock and my MAF table to an LQ4(running a Northstar TB)stock MAF table. After doing this it ran pretty good without this issue. So this morning I was driving around, unplugged my MAF to retune the VE table and all was going good until a part-throttle accel and then it started again. Here is three scans. The first is before I reset the forementioned tables. The second is from after resetting tables and it running decent, and the third from this morning when the problem cropped again. Any ideas on what could be causing this?
1st-http://denverpala.com/impala0404pmbad.hpl
2nd- http://denverpala.com/impala0405pmgood.hpl
3rd- http://denverpala.com/impala0406ambad.hpl
