Hey all,
I have been working with a couple of the new 8 speed transmissions lately. One for a 2015 Denali and one for a 2015 Escalade. Both have TVS2300s on them.
The DD tables are represented in throttle% vs. VSS and are reporting in axle torque. From my understanding, the ecu references this table to see how much "axle torque" is being commanded. Once it has a number I'm guessing it must have some sort of transmission table that it looks at to see what gear should be requested. for example:
Cruising in 6th on the highway (1:1) requesting 400 ftlbs at 2500 rpm. If I was to then request 800 ftlbs (but the engines peak torque for 2500rpms is 600) it should then look at the transmission table and know that it can make the required 800 by downshifting to 5th? Or if that wasn't enough, maybe 4th? This would be handy since I have noticed that these motors don't need to be spun to redline all the time to make good power.
Maybe there is something like this already in place? Any help finding it would be greatly appreciated.
