expressfuel.png duramaxfuel.pngim just curious as to why everyone has to run their own tables for timing through the calculator? if someone has lets say a 2005 lly why couldn't he make a tune, and then other people with a 2005 lly use it? as far as ls1 tuning ive used other peoples tunes as a guide line and they were very close to working perfect. hand held flash tunes I assume use the same tune for every truck?! maybe im wrong
I have a 2006 chevy express lly and for some reason when I run my numbers through the calculator they don't come out right. my main concern is the base fuel pressure table... you can see mine starts out at 33 34 48 then 0 5 10 ect where the dmax truck is 0 5 10 ect... I tried copying just my table from 0 up but tha didn't work either. ill attach my stock tune and the start of my 20/20 but I didn't save the timing table because it was so far off when trying to use the calculator. I guess my biggest question is, is it because its a van compared to a truck or do I just suck and cant get the calculator to work?!
I loaded the timing tables from a duramax tune into my van and holy wow! that thing moved out way too much for its own good haha Im new to diesels and don't want to kill my van but it seems like if my motor is just a detuned version of the truck why couldn't I run a stock truck tune? or atleast a truck tune with economy built in?
thanks! also attached the tune where I used a truck timing table.....
stock2006llyexpress.hptlly2020tune.hptextremellytuneexpress.hpt
