Understood - The reason I mentioned it is becuase you mentioned that the reason the coefficent tables aren't set to allow the throttle to open more is becuase of warranty reasons. I took that as meaning that this change is more likely to cause engine and/or trans problems becuase of that statement (assuming that the car was driven the same as it was without these modifications).
I understand that it won't always be the case, but it sounds like the chances of damage are higher if you do this - that's all that I'm saying (or trying to understand, I guess).
Thanks!
