I tune a lot of cars in SD 2-3 BAR. They always take like 6 seconds to fail the MAF after a flash or battery disconnect and they run rough. Once the code sets they run smooth.
Many of the cars I tune are race only cars with a battery disconnect to cut all power after a race, the PCM resets and it has to set the code again. Many owners are old school and refuse to not cut the power, they want me to fix the issue but I have tried everything.
Is it possible to have more MAF parameters available so we can set the time needed to fail the MAF and switch immediately to SD? This should be possible.
