1. Copy axis, left or top, not working. If you open base file, then compare file, then try to edit axis on any tables, switch between stock and compare, always stock is displayed. I'm reporting this long time, makes tune creation much longer.
Example here:
https://www.youtube.com/watch?v=KVoTDvrt1Z8
2. On 2.24 in single field, for eg ford calibration, Flow rate low, i could select digits with mouse and use ctrl+c, now this field is gray (understand, because not editable in compare mode), but its also not selectable with mouse. I have to use right click and then with mouse copy, i can live with that, but after paste, it copies also for eg lb/s etc.. Example, i want to copy: 73.99080, after paste i get 73.99080 lb/h (i just made paste here).
