Hello,
I am new to this whole arena and basically seeing if what i am thinking could be correct or if I need to start looking elsewhere.
I put a 6.2 l99 block with the lsa charger into my 66 c-10 p/u. I had the harness for a CTS-v made from current performance and was running the 6l80e. Now I eliminated the transmission computer because I am running a stand-alone for the transmission but I did splice together the communication wires so that my obd connector works. I have a local tuner here that works with these cars put in a basic tune to get the car started. At the time I didnt have my fuel system complete 100% so he put the program in based on what we had spoke about. I finished my rails and injectors and went to start it and nothing. If I use starting fluid it fires up no problem and will stay running as long as I keep the finger on the can. So i think it is getting a cam signal to fire injectors and keep timing, spark, electronic throttle works, etc, but I checked and have no injector pulse. He told me I must have a wiring problem. I am wondering if that is more a computer or program problem?
I am running a return style system w a fuel cell, 90# injectors, aeromotive 1000 pump and currently have it set to 50 lbs. of pressure. i have an10 feed and return lines. Any help would be great.
