Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 70
Thread: Rant about 2.25 Scanner
  1. #41
    Sep 2002
    Chicago, IL
    6,394
    Quote Originally Posted by MikeOD View Post
    Have you tested (or can you test) any specific USB to serial port adapters? I haven't had a PC with a com port in years. I'm happy to get an adapter...but I want to get one that I know will work.
    This is what I picked up a couple weeks ago to test, but haven't tested it yet: http://www.amazon.com/TRENDnet-TU-S9...trendnet+tu-s9
    The one I have been using is super old and is funky with the drivers.
    We got this guy Not Sure, ...
  2. #42
    Sep 2002
    Chicago, IL
    6,394
    One question though.. how does it know which port to use if you have multiple com ports on a computer?
    The software scans for open ports, then tries to connect and communicate on those ports to see if the serial wideband you've added to your channels config is present.
  3. #43
    Feb 2006
    South Carolina
    1,525
    Most of the adapters based on the Prolific chipset should work fine. They are very common in many of the USB - serial adapters.
  4. #44
    Feb 2006
    South Carolina
    1,525
    I have used the serial feature on a native serial port (I use a CF-52 Toughbook) with my LC1 and it was very smooth. I like it very much.
  5. #45
    Advanced Tuner Auto-Hentzschel's Avatar
    Sep 2015
    Schleid, Germany
    341
    My LM-2 does not have a serial port on it only USB. My Lenovo X201 is also without serial port, if I try to connect it with USB, the scanner can't find the inputs, the serial channels are empthy
    Anyone who can tell me my mistakes?
    thank you!
  6. #46
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Auto-Hentzschel View Post
    thank you!
    I think you need to use the MTS serial In/Out function of your LM2. The same connection you would use to string multiple Innovate devices together. You may have to purchase a MTS serial to DB9 program cable (P/N 3840 I think) to make it work, if the device doesn't come with one.
    Jaime
  7. #47
    Sep 2015
    Schleid, Germany
    341
    Jaime, now I got it ... how stupid. But need to order this cable 3840. Think serial input is better than analog input. Hopefully can config a good working AFR error graph!!
  8. #48
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You aren't making an AFR error graph in 2.25 yet.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  9. #49
    Sep 2015
    Schleid, Germany
    341
    But I can use the difference between desired AFR and WB AFR for AFR error correct!
  10. #50
    Sep 2002
    Chicago, IL
    6,394
    Not yet. Math parameters are being developed as we speak though, so it shouldn't be much longer.
  11. #51
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    No. Custom PID's don't exist yet
    You can make a graph(histogram) for commanded AFR.. then one for actual AFR, and then just flip between the two to see differences
    And you can make a chart vs. time that has commanded and actual on top of each other so you can see it better while logging..
    But there's no way to make an AFR PID right now. They are working on it.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
  12. #52
    Sep 2015
    Schleid, Germany
    341
    this is what I mean... its only a litle difficult for me to find the rght words... I'm a German
  13. #53
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You speak English better than I speak German, lol
  14. #54
    Sep 2015
    Schleid, Germany
    341
    haha.
    I use a excle file to find the AFR error between comanded and actual AFR!
  15. #55
    Sep 2015
    Schleid, Germany
    341
    Quote Originally Posted by ElecTech View Post
    I hate this scanner
    either it don't show me what I need or it crashes over and over again.
    I bought the Innovate serial cable and also a Serial/Usb convertor cable. driver>connection> COM port1 all looks perfect. but no serial channel is to see. the chanel disappears as soon as I click the scan button!
    If I change the settings to try different settings, one time the scanner runs two times it crashes.
    I could cry!
  16. #56
    Sep 2002
    Chicago, IL
    6,394
    We can fix the crash for you if you tell us how to reproduce it.
  17. #57
    Sep 2002
    Chicago, IL
    6,394
    I just put up a new beta that fixes the crash on scanning start that was reported. This should fix your issue.
  18. #58
    Mar 2010
    Texas Hill Country
    3,299
    So I had a few Transmission PIDs a few days ago and after an update I have none. Seems like a step backwards? 2016 Mustang GT....
  19. #59
    Sep 2002
    Chicago, IL
    6,394
    What version of software?
  20. #60
    Sep 2015
    Schleid, Germany
    341
    I found out, the LM-2 send not the real AFR value to the serial output. If I calculate correct than seems it to be 500 beats for 14.7 AFR I set the function in the transformer to (input/34,013605442176870748299319727891)+0 = output.
    can anyone confirm that?
