just put in a 3400 stall precision in a 2014 Chevrolet SS, the tables for TCC are different then all the other E38s, it does not have the "regulator offset" table to set the base TCC lockup psi.
i tried maxing out all the values in the TCC tables but it will still have a base TCC psi of around 35psi then slip, raise the psi to stop the slipping then back down to 35 and slip again causing it to hunt..... the problems we had on the original E38s until HPtuners added the offset table....
im gonna try one or two more tricks but is there a reason that table was not added? i need the TCC to hold min 75psi at all times to keep the converter alive...
so i guess i need hptuners help on this one......
the attached tune is a trial having almost every table maxed out, but it did not help....
2014 CHEVROLET SS GERALD TUNE 11.hpt
