Need some help, 2003 5.3 stock long block with an intake like professional products or something. car fires and sounds like it is running on 4 cylinders then dies. Using stock file with the typical deleted codes. after running for roughly 30-45 seconds the passenger side manifold is getting hot but the drivers side is barely warm (at the ports). DBW is not responding at all and in the scanner it will not let me raise the idle manually. Please help.
