Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: 2015 Colorado 2.8 diesel
    Tuning Addict
    6,829
    I know I'm not of any help on this, but since my truck should finally be showing up next week, I was curious to know the gains you were getting out of this one? I don't plan on tuning it immediately for warranty reasons, but curious to mpg, hp and tq gains.
    ~Greg Huggins~
    I got gains of 51hp and 150nm of torque in an auto. Haven't had mpg checked yet.
    Jul 2007
    Perth, Western Australia
    38
    I am in the process of picking one of these up as well. After looking at the factory tune that was posted, where the heck do you start to tune these things? What tables were the ones you changed?
    Colorado on the way.....
    Hahaha it's a bit that way at first.
    Mode 1 is 2wd
    Mode 2 is 4wd high
    Mode 3 is 4wd low
    Then you have low med and high alt maps
    I firstly removed all torque limits
    I tuned mode 1 low alt for our location.
    I didn't need to adjust fuel pressure only main inj table and boost map to get the afr's safe and egt down.
    Hope this helps
    Jul 2007
    38
    All I have been able to find is the desired fuel pressure tables with the 3 alt's and 7 modes in the fuel system tables, can't see a boost table or torque limit table to save my life.
  6. #26
    Boost table is under torque management, sc/Tc boost control, desired boost low alt
    Fuel is under fuel tab, diesel injection quantity, injector pulse width, main inj pw table 0
  7. #27
    Tuning Addict
    6,829
    I was told by a gm rep that there was fixing to be some sort of recall on the diesel colorado's? My truck was supposed to be at the dealer this last Wednesday and never showed, so not sure if the two are intertwined or not? Hopefully won't require people all ready tuning these to relicense due to an os change
    ~Greg Huggins~
  8. #28
    Oct 2013
    Gold Coast
    11
    does anybody know if its possible to disable the EGR on a 2015 rg colorado,
  9. #29
    Oct 2007
    Hi Bogga
    Where did you remove the torque limits from I'm having trouble working it out if I was to send you my tune would you be kind enough to have a look at it and tell were I'm going wrong.
    Should have said its a manual.
    Quote Originally Posted by Bogga View Post
    Mode 1 is 2wd
    Mode 2 is 4wd high
    Mode 3 is 4wd low
    Hope this helps
  10. #30
    Aug 2008
    Australia
    31
    "does anybody know if its possible to disable the EGR on a 2015 rg colorado,"
    Removal of the EGR was easy on the 2015 model, just find everything in the DTC's section that refers to the EGR, change them so they don't throw a code, then just unplug the EGR, I just did a 500k run with this and no issues so far.
    This is better than modifying anything, as you just plug it back in and upload stock tune when servicing or claiming warranty.
  11. #31
    Aug 2008
    Australia
    31
    Quote Originally Posted by LILBRT View Post
    Hi Bogga
    I found disabling "torque shaping" makes a big difference, makes it feel snappier through the gears and launches quicker.
  12. #32
    Oct 2013
    Gold Coast
    11
    i have used a blanking plate ,but not sure where to unplug it from
  13. #33
    Aug 2008
    Australia
    31
    Quote Originally Posted by Mickey350 View Post
    Its at the back of the engine, between the rocker cover and the firewall, you don't need the blanking plate, just unplug the solenoid and disable the DTC's and that its, easy to reverse for "warranty" reasons, I have been running my 2015 like this for few months, no issues yet.
  14. #34
    Oct 2013
    Gold Coast
    11
    Thanks Kung foo Kamel .
    have you tuned yours as well ,boost fuel etc .ive done the auto,shifts much better ,driver demand adjustments seem to make a difference
  15. #35
    Tuning Addict
    6,829
    I'm only after better fuel economy for mine - will killing the egr cut down on regens and bump up economy - if it's like the V8's - I imagine it should, but as you've actually put some serious miles on yours - I'm curious of actual gains? I drive around 100 miles a day round trip, so after economy more than anything... Don't really care about the power gains even though it could use it up top a little... Pulling the crooked mountains that I do - it's already peppy enough - already breaks the tires loose when getting back into throttle in the steep curves... Anyway - just wondering...
    Also just to clarify - GM can still see when the tune has been changed without their knowledge even if you return it to stock - as long as you don't mess with injection timing - they typically look the other way on diesels... They would actually prefer they not have all of this emission junk on them as it usually causes engine problems - was surprised when an engineer said that
    ~Greg Huggins~
  16. #36
    Aug 2008
    Australia
    31
    I have upped the boost a little, but mainly removed all torque management stuff and the EGR, I think I increased line pressures when it direct shift by about 5%, the car goes a lot better now, not sure were to start with the shift patterns, It was easy to workout with Commodore as the 4L60E's had a terrible factory shift pattern, but the Colorado seems fairly good, has so much power even down low, so transmission seems to respond well most of the time.
