4l60e problems
set`1.hpl Vcm scanner log
transmission scan.cfg Config
zxset2.hpt Tune
Ok heres my log config ^ and my scanner file. Shift time errors here and there I even recorded the times it was shifting and changed them in the tune and its still off sometimes. it even shifts faster than what it should sometimes at .200 seconds when its like .425 commanded. Also if you watch the log my actual line pressure current goes over the desired line pressure it flobbles .02 over and then back to 1.05..is this normal all the trans pressure is stock. Any ideas thank ya
