Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Whats up with MAF1 table in 6th GEN cal??
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    What's up with the last two cells of the table?
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Dec 2006
    Rockwall, Tx
    247
    It almost resembles the last cell in the MAF1 table of the 16 Z except this has a much higher value.
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Yeah if you follow the red dot, it is a huge jump on the far end of the graph view. The axis jumps way up too.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    Jun 2006
    536
    I'm just wondering if its a boo boo in the file as we know we can extend it..... just weird how MAF 2 goes out deep....I'm sure in the OS there has to be a switch to point which MAF is used....
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    this one isnt like that..
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    Jun 2006
    536
    What's that from a stock 6th GEN cal?
    Jun 2006
    536
    What's the verdict on this table? I'm gonna stretch it out regardless but none the less where is the error in this?
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    There is no error. That's how it is setup from the factory.
    Jun 2006
    536
    Quote Originally Posted by Engineer@HPT View Post
    Interesting....I guess we will fix it then..
    Sep 2015
    Garner, NC
    28
    After coming across this in my stock file tonight I had the same reaction that it is an error. After seeing this thread and looking at it closer GM chose to give the maximum resolution across the actual operating range of the stock engine. Anything above that will be a linear interpolation. If you are exceeding the stock operating range by any significant amount it makes sense to modify the x axis (Hz) and refit the curve accordingly.
    Mar 2010
    Texas Hill Country
    3,299
    Newer Fords do the same thing
    Tuning Addict
    Jan 2015
    6,802
    Got a really stupid question since I haven't had the luxury of maxing the MAF table on these yet.... What is the second MAF table used for in general? I know earlier platforms used the second tables for higher flow zones but both of these tables have the same hz zones and in the tunes that have both populated, they are reasonably close to being the same, SO is it possible the calibration is using the second table as a "guessed or calculated" exhaust flow calculation that most newer gens are using in their core programming for airflow in and out calculations for diagnostics and torque modeling? Probably over thinking it, but I know in my GM training days they always discussed the ecm being able to calculate exhaust flow to "more accurately" model inlet flow? Never fully understood it then - not sure I still do. I just know from the ones I've seen from the factory using the second MAF table, that they were fairly close if not slightly under the primary MAF table...
    ~Greg Huggins~
    Tuning Addict
    Jan 2015
    6,802
    Well, this one actually has both 100% identical? Possibly just for the intake runner's being switched or something??? BUT the intake flow shouldn't change, SO I have no idea. Probably just really over thinking things?
    ~Greg Huggins~
    Mar 2010
    Texas Hill Country
    3,299
    two maf tables for twin turbo applications.
    Tuning Addict
    Jan 2015
    6,802
    That would actually make sense for the ones using two MAF's, but what about the 5.3l truck above?
    ~Greg Huggins~
    Mar 2010
    Texas Hill Country
    3,299
    just shared tables, the ecm never looks at the second table (as far as I can tell). there are unused tables throughout all the tune files, honestly. sort of like a "blank" button on the dash when you don't have one of the available options.
    now some of the older stuff, mid 2000s, did have a high and a low MAF curve but that was different.
    Tuning Addict
    Jan 2015
    6,802
    Quote Originally Posted by Higgs Boson View Post
    Kind of what I thought. Just wasn't sure anymore sense everyone was talking about one table vs the other or at least has intermittently been on the forums. Then making it even more odd was the fact that some of the newer ones were actually populating the second table from the factory...
    Thanks for confirming what I thought I all ready knew
    ~Greg Huggins~
    Advanced Tuner WS6HUMMER's Avatar
    Feb 2006
    Pineville La. US
    771
    So I'm tuning a cammed 6th gen camaro and just noticed the MAF curve jumping from 8550 to 15000hz like in the original post. Seems like fueling would be stuck with one value for the higher RPM's, please tell me I'm missing something.
    99 T/A WS6, original LS1 turbo
    Jun 2006
    536
    Quote Originally Posted by WS6HUMMER View Post
    If you read this thread you haven't missed anything! Just extend it by rescaling the axis and keep going.
    HT
    Feb 2006
    Pineville La. US
    771
    Quote Originally Posted by Redline MS View Post
    HT
    Thanks for bringing that to my attention, I completely missed that. I scaled it to a 2011 6.2 truck axis that I had tuned, I can't wait to see how this goes down on the dyno.
