Results 1 to 9 of 9
Thread: Power cutting at high rpm
    May 2014
    12
    Hi
    Can someone please take a look at this file and let me know where I am going wrong please?
    No matter what i do i cannot make it run over 15psi of boost without cutting and jerking at about 5000rpm.
    This tune made 350kw at about 15psi of boost, but as soon as i raise the desired boost duty it will cut at high rpm, if i raise it a bit more it will cut in mid range.
    Really lost on what to do from now. I would like to get 375kw out of this setup. not sure what is causing this! want to go to e85 later also.
    350kw.hpt
    Cheers
    Dec 2009
    Bayside, Melbourne, Victoria
    301
    It may help to identify changes if you attach the stock file also.
    It doesn't look like you have changed the under/over hystersis thresholds?
    Feb 2014
    Sydney
    295
    A log file may also help
    Tune with actual data not simulated data!.....Applied Road/track Tuning
    May 2014
    12
    what do you do to those values Grant?
    May 2014
    12
    I do not have a log, i guess i could put it back on the dyno and make one
    Feb 2014
    Sydney
    295
    If you can capture the event on a log it will potentially give you the answer or at least point you in the right direction or eliminate things that it is not.
    May 2014
    12
    how do you log / view events with the scanner?
    Feb 2014
    Sydney
    295
    Quote Originally Posted by g6e View Post
    Sounds like you are just starting out then you have a way to go if that is the case then you need to read "working with VCM sanner" in the help file on the scanner page when you can make a log of the problem area post it up on the forum and I am sure forum members will give you feedback.
    Feb 2015
    Perth, Australia
    974
    open loop boost control
