Originally Posted by
Higgs Boson
Can't view tune on this computer.
First, put everything back to stock regarding airmass, tm and dd tables. make sure all your torque limits like axle torque, tcc torque, etc etc are all maxed out. make sure your brake torque multiplier is 1.0 not 0 since it's a multiplier. there is a good chance you are being limited by something other than DD or PT......
next try to imagine what your car should make....800 rwhp? 1000 rwhp? whatever. let's say 800 rwhp. That is 975 at the motor (give or take whatever).
kilowatts is 1.34 X HP so you want your DD 100% row to be 1500 across (for now).
let's say stock DD is 600. 1500/600 is 2.5
multiply your Peak Torque table by 2.5 in the area where you are having a throttle closing issue.
leave airmass stock for now.
adjust accordingly DD and PT.
If there is one issue I am not having, it's throttle closing. my airmass tables are stock.
if these changes don't work, you have a limiter still active somewhere else. you also need to make sure to tune the GMVE table.
