Page 9 of 9 FirstFirst ... 56789
Results 161 to 174 of 174
Thread: Knock Retard hell! Desperate for help
  1. #161
    Tuning Addict
    Jan 2015
    6,815
    Boundary-ECT-RPM = eoit Boundary-ECT-RPM-Injection Pulsewidth = soit
    Leave your ect table mostly stock since you have a stock cam, head setup - your running more boost, so dial back your colder temps some - otherwise you might wind up with cold throttle snap lean outs...
    Keep the stock boundary of 520 up to 1000 rpms... End at 600ish around 46 to 5100 - your probably good to go to 610 or so to be honest... add 20 to the boundary by 2000 rpms (this is for the boost addition) / interpolate between these two remaining points and then smooth a couple of cells past that - should be good to go from that point... Redial in your MAF and VE tables - enjoy...
    ~Greg Huggins~
  2. #162
    Tuning Addict
    Jan 2015
    6,815
    When HPT first introduced 3.0 it had injection timing in it's scanner - what happened to that - I honestly don't remember it working, but would be nice if we still had it and it worked
    ~Greg Huggins~
  3. #163
    Jul 2013
    Clear Lake tx
    423
    Boundary-ECT-RPM = SOIT Not eoit oohhh really? This whole time i thought that was eoit
    Cool thanks...ill re-try this and repost what i come up with...man i thought i had it figured out too, thinking this whole time that the total 410 boundary was the eoit. Thanks again
    Sorry micheal to thread jack but i am using this thread as a learning opportunity.
    2010 CTS-V A6, Airaid CAI, 2.4 pulley, ported ls7 throttle body, ID850s, ARH 1-7/8" headers and X pipe, TR7IX plugs, MSD wires, Elite catch can, ZL1 lid and Track Attack HX
  4. #164
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I think I started with that one then added the cam stuff and chart to make it more visual
    Check it out and see if anything is wrong--it's been a while since I've looked at it. I just do what Ghuggins says when it comes to inj timing these days
    There are a couple of tabs--just the one it opens up to has the charts and stuff, you can mess around with it, I didn't put a PW on it
    EOIT gen IV - LS2.xls
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  5. #165
    Jul 2013
    Clear Lake tx
    423
    Awesome...thank you, looks similar to the one i have but with some extra goodies
    Edit:THAT IS A COOL SPREADSHEET
  6. #166
    Jul 2013
    Clear Lake tx
    423
    here is what ive worked up, 2 different examples (less and more aggressive) boundary targets. just to see how how it worked out in the calculator. taking everything GHuggins advised into consideration in post 161 and doing a little more reading about the ECT table. from what I gathered in this thread http://www.hptuners.com/forum/showth...lculated/page3 the ECT and RPM tables are there for make up PW?
    so I did one table (less aggressive screenshot) keeping my ECT table completely stock and raising the boundary up slowly as Greg suggested and in the highest cells getting a boundary of 610, now if I go to the calculator that Schpenxel linked up, that gives me a final normal EOI of 500.
    in the more aggressive screenshot I actually lowered my ECT table by 50 across the board but adjusted my boundary lower in the idle cells (still with a final EOI of 410) and up to a total boundary of 600. all and all this was no more of an aggressive ramp but the final calculated EOI was higher at 540. but the actual boundary was 10 degrees less.
    just messing around and having fun playing with the different options. what do you guys think about the actual ramp up? again I tried to follow Ghiggins advice on when and how much to add vs RPM's.
  7. #167
    Tuning Addict
    Jan 2015
    6,815
    I like them both Josh You'll want to play with the ect table - this is the more important for soi... Durring a cold start - watch your temp gauge - once it starts to flicker or your coolant temp is around 100 to 120 in the scanner - snap the throttle lightly - watch for lean out - no lean out, do a heavy stomp - good air fuel target - your close... NOW move the ect table (most likely back towards 110 for yourself) - same temp conditions - same experiment - BUT NOW pay attention to throttle response - your looking for quick, crisp response... After all those conditions are met - call it good - might need to raise peak boundary more? Dial in VE and MAF - enjoy...
    You might also want to subtract 20ish from -40 to 133 in the ect table before doing all of this...
    ~Greg Huggins~
  8. #168
    Jul 2013
    Clear Lake tx
    423
    Great advise and stuff to look for...like always thank you for your input i will lower the cold ect areas a hair more and keep a close eye on the above mentioned stuff and report back after i have downloaded it back in...of course that wont be until i get the aem 30-0333 in which i am planning for this weekend. So hopefully i can get rockin and rollin on this stuff next week...im excited!
  9. #169
    Tuner in Training ants-gts's Avatar
    Apr 2015
    dapto ,nsw
    49
    sorry wrong thread
  10. #170
    Aug 2014
    Central, LA
    737
    I made a degree wheel marked for 720 degrees. Not sure if it will be useful for anyone but these labels make more sense for our purposes to me.
  11. #171
    Tuning Addict
    Jan 2015
    6,815
    Quote Originally Posted by sevinn View Post
    Thank You This will save time with having to write the numbers in by hand
    ~Greg Huggins~
  12. #172
    Aug 2014
    Central, LA
    737
    Thank you for all the good info in this area. Once I realized the degree wheel you posted on page one was scaled double I decided to make this thing lol
    The only thing I'm not entirely sure of is how to exactly get "soit," but I see where you put the formula earlier and I can try to get it based off of eoit and rpm somehow. I'm not going to bother with this stuff quite yet because I'm about to make some pretty major fuel system changes that should decrease my pw's by a good amount and don't want to have to do it twice!
    Next thing on my plate is finally figuring out how transients work. Oh joy.
  13. #173
    Jan 2014
    Australia
    1,984
    just make sure u have your fuel system mechanically spot on before adjusting transients/EOIT ect, u can chase your tail for a while if there is an issue, there are some calculators that work out SOIT based on EOIT/RPM/IPW just remember to add all the EOIT duration tables in like the makeup duration also to your workings out
  14. #174
    Aug 2014
    Central, LA
    737
    Good call thanks I'll look for something. I had a revelation this morning that my flex fuel setup may make "soit" at the very least hard to pin down since I could end up with very different fuel comps in the car. Compromises will have to be made.
