Results 1 to 10 of 10
Thread: Silverado 2004 6.0 4l80e with cam wont idle rpm fall in gear would appreciat the help
    Sep 2014
    12
    duration 50 ,220.220 intake 527 exhuast 527 lobe 112 center line 108 engine rpms fall very low when put on reverse or drive wont idle and geting error codes on torque connverter and trans 4l80e and torque managment errors
    Tuner Monty's Avatar
    Apr 2012
    173
    Here is my 2004 6.0 4l80e with 219 226 525 112 i had the same problems.. this is what i did to fix, too hard to explain it, so use my tune as a compare file ..
    Sep 2014
    12
    thank you the engine sounds alot better but if i go to reverse or any gear rpms still drop very low and i keep gettinng p1689 torque dileverd circuit
    Apr 2012
    173
    Quote Originally Posted by anayaracing View Post
    Can i have a look at your new tune file i'll try and help
    May 2011
    Celina, TX
    8
    What converter do you have?
    Feb 2008
    Scott, LA
    12
    Is the cam and converter new? Have you re-tuned the base idle airflow for P/N and in gear?
    2004 GMC Sierra 2500HD 6.0/4l80E
    Sep 2014
    12
    converter is a brand new 2500 and cam are new yes i have will post the new tune
    Sep 2014
    12
    Sep 2014
    12
    ass soon as i put it into drive the car shuts down the rpms fall to low and i keep geting those codes and randome missfire the silverado used to have 5.3 and i swaped it for 6.0
    Apr 2012
    173
    found a video series for ya might help https://www.youtube.com/watch?v=5A5U8mIgCU8
    also if you changed any of your trans parameters, change them all back.. and start clean..
    but this video should help you with idle
    peace
