Results 1 to 12 of 12
Thread: Injection timing
    Jul 2011
    Fort worth, TX
    126
    Injection timing
    Been doing a lot of interet reading on safe timing numbers but most I am reading is all dealing rib upper rpm wot timing, my factory 05 table has a lot of negative numbers down low, what's it safe to bring these up to?
    15 C7Z M7
    I'll Pm you.
    Jul 2011
    Fort worth, TX
    126
    Quote Originally Posted by Orange Stroker View Post
    I'll Pm you.
    05 5.9l cummins manual 6speed pulseadd.hpt
    15 C7Z M7
    Tuner 2007 5.9's Avatar
    Feb 2015
    Nor Cal
    93
    Timing is relative to pulse and rpm. There is no defacto number to run or not run. You should look at a timing calculator to best determine max timing with a given pulse and rpm
    Les Szmidt
    Silver Bullet Tuning
    HP Tuners BETA Tester for 2003-2005 Cummins
    [email protected]
    Dec 2015
    37
    Quote Originally Posted by 2007 5.9 View Post
    This guy knows stuff.
    Jul 2011
    Fort worth, TX
    126
    Been using the efive calc
    15 C7Z M7
    If you are using EFI Live calc, I've found you usually makes peak power 55-60% BTDC at WOT and 35-40% in the cruising ranges for best fuel mileage.
    Dec 2013
    Down Under
    168
    I'm going to try a couple of things from this paper to see what effect I can get mpg wise. It's an interesting read
    http://www.tytlabs.com/english/revie...3_009hotta.pdf
    Feb 2015
    Nor Cal
    93
    Quote Originally Posted by Tiffo60 View Post
    Did you use that calculator when you built the tune you posted?
    Les Szmidt
    [email protected]
    Jul 2011
    Fort worth, TX
    126
    Yes and no, I have a habit of changing duration and not always re-inputing the data in the calc, and I just learned that I was doing a couple of inputs backwards in the calculator
    15 C7Z M7
    Feb 2015
    Nor Cal
    93
    Ok..because the timing split that is shown in that tune is not what most would consider ideal..its borderline unsafe....
    Not enough timing is just as dangerous as too much...its a balance between, spool, smoke, power and parts life.
    Les Szmidt
    [email protected]
    Jun 2010
    29
    Quote Originally Posted by muz79 View Post
    Thanks for the paper. I found it a good read.
