Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Any suggestions
  1. #21
    Oct 2007
    Crawfordville, FL
    2,412
    Well, as far as I know, our scanner is the fastest on all fords.
    The missing DMR's will not affect the rate at which our scanner engine works, and I know Eric is actively working on adding those DMR's for you guys, so it shouldn't be much longer.
    Yep, we are well on our way to making VCM Suite/Scanner the best on the market for the AU Fords.
    Eric Brooks
    HP Tuners, LLC
  2. #22
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Check your task manager to see what your physical memory is reading. Its odd I haven't seen anyone else report this issue nor have I been able to recreate it so the only thing I can think of is a pc specific issue.
  3. #23
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    Has support added my request for that FGX strategy yet bill/eric ?
    Edit
    That was quick lol thanks
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
  4. #24
    Feb 2014
    Sydney
    295
    With the scanner opened the physical memory is registering 39%
    The strange thing is after upgrading the RAM from 1 GB to 2 GB it appeared fine for around 10 minutes while I was moving around it before becoming grayed out
    Tune with actual data not simulated data!.....Applied Road/track Tuning
  5. #25
    HP Tuners Support
    (foff667)
    28,268
    One thing you can try is to close the scanner & delete all the files from your hptuners-settings folder(they will regenerate the next time you open the vcm scanner) if one of these files becomes corrupt it could cause odd issues with the scanner & editor.
  6. #26
    Feb 2014
    Sydney
    295
    Bill
    Looks like that worked it appears normal after clearing hptuners-settings folder and starting the scanner again thanks for your help and perseverance.
  7. #27
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by JETURBO View Post
    Edit
    What was the OSID? I need to make sure it has the new parameters.
    Eric Brooks
    HP Tuners, LLC
  8. #28
    Feb 2013
    519
  9. #29
    Oct 2007
    Crawfordville, FL
    2,412
    The latest beta should have DMRs for that OSID, give it a shot and report back.
    Eric Brooks
    HP Tuners, LLC
  10. #30
    Feb 2014
    Sydney
    295
    Bill, FYI it appears when I try to change the graph layout screen (as it has the incorrect vertical Axis, airmass instead of load) the screen goes grey again, follow the above proceedure and it displays correctly again.
