Hey guys I was recently playing with a LS3 engine/GMPP E67 controller with a procharger on the dyno and we ran into some issues with code P1516 popping up in high rpm dyno pulls. I can not verify if the code is popping up before or after I lift at the end of the run but right after I lift and get the car slowed down it is in reduced engine power mode and p1516 is there.
We did verify the throttle body was not obstructed or sticking in any way we also changed the throttle body out for a brand new unit with no change.
The blow off valve on this particular set up is somewhat far away from the throttle body but not anything too crazy its just on the supercharger side of the intercooler.
This set up is pegging the mas air flow sensor but fueling still held really nice on the wideband and did not appear to be a major problem, the throttle appears to work just fine in all normal driving and idle conditions but under wot it always screws up. The injector flow rate and stoich values have been scaled for larger injectors.
Any and all help is greatly appreciated.
Here is a log and a tune file:
FINAL FOR NOW WITH P1516.hpt
wot 4.hpl
