Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 185
Thread: VCM Scanner AU Ford Update Thread
    Oct 2007
    Crawfordville, FL
    2,412
    I have an update in the works that will add the following DMRs to the FG Falcons. If there is something you want to see that is not in this list. Please let me know ASAP. Less work for me to add it now, than it is months later.
    Code:
    LOAD
    Cam Angle
    MAP per Airmass (Current)
    MAP at Zero Airmass (Current)
    Manifold Air Pressure Sensor
    Knock Retard
    Inj. Pulse Width
    Manifold Charge Temp
    Average Air Mass
    Borderline Knock
    MBT Advance
    Idle Adapt (STIT)
    Desired Boost
    Boost Error
    Wastegate Duty Cycle
    Desired Brake Torque
    Engine Brake Torque
    ETC Vacuum
    ECT Throttle Angle Error
    ETC Effective Throttle Area
    Trans Output Shaft RPM
    Trans Current Gear
    TCC Slip RPM
    TCC Applied (flag that shows if the TCC is locked)
    Throttle Angle Source
    Fuel Source
    Spark Source
    Idle Speed Source
    Torque Source
    Eric Brooks
    HP Tuners, LLC
    Advanced Tuner JETURBO's Avatar
    Feb 2013
    519
    No more two weeks
    FG F6 400+RWKW .....10.9 @ 132mph.... FIRST 10sec F6 in SA ( sold )
    DYNO DYNAMICS 1200hp ...... Tuning weapon..... ( sold )
    OFFICIAL JONNY TIG INDUSTRIES SUPPLIER ..... Biggest and lightest intercoolers for B and F falcons
    SUBARU BRZ ......AVO TURBO KIT coming......soon
    VF R8 CLUBSPORT SV...... 340FWKW.....ASE BIG SINGLE KIT .....one day
    Oct 2011
    QLD, Australia
    436
    Eric is there an ISC integrator in there? I've used it in SCT on B series. All of the rest look good so far. Just need them in B series now please.
    Ford BF Turbo Ute,Stock head/cams, In house built bottom end,Atomic Springs, Forged Rods,Cosworth Pistons,Atomic Billet oil pump gears,ARP Head/mainstuds,Process West Stage 3 Cooler Kit- Plazmaman plenum,Precision Int.Gate 6466,Manta twin 3" exhaust,ID1000s Plazmaman surge with Holley 12-1800 pump, Home Built ZF6H26, On United Pump E85 499rwkw 10.5@135mph https://www.youtube.com/watch?v=dgZupPhrMss
    Latest mods, FG intake manifold conversion and ID1300s-500rwkw, Yet to see the 1/4Mile
    Oct 2011
    QLD, Australia
    436
    Quote Originally Posted by JETURBO View Post
    No more two weeks
    Is there anything missing you can see JET?
    Feb 2013
    519
    I honestly don't know what the scanner logs now so unsure but if there is something missing it looks like it won't take to long to add
    If what you have asked for is the idle air integ that's a winner, if not add idle air integ please
    Aug 2012
    Melbourne Australia
    344
    + MAP Volts (good for setting up T-MAP)
    + Calculated fuel mass per stroke (if possible)
    Feb 2013
    519
    Looks like load is up the top daz
    And Map V for sure
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by 45T-XR View Post
    That's in the list. We call it Idle Adapt (STIT).
    Eric Brooks
    HP Tuners, LLC
    Jun 2014
    Eden
    88
    cam overlap
    pedal position
    actual throttle blade angle
    Thanks for your help
    Mark H.
    Mar 2015
    26
    1) Desired gear (Requested shift flags an up shift or downshift on Forscan prior to the shift event occurring)
    2) Desired TCC slip
    3) TCC amps (range of approx 0-0.75 amps current supply to TCC Solenoid (logged in Forscan)
    4) % torque truncation
    5) Clutch slip (transmission)... It's in the TCM cause it will throw codes but might be a tough nut
    Oct 2007
    Crawfordville, FL
    2,412
    Quote Originally Posted by Huddo View Post
    cam overlap
    pedal position
    Can you not log pedal position and throttle angle now?
    Jun 2014
    Eden
    88
    would need to recheck as have not looked for a little while
    Mark H.
    Sep 2015
    44
    Trans Shift Pattern Map
    Apr 2014
    360
    when are you looking to have this pushed through?
    Oct 2011
    QLD, Australia
    436
    Quote Originally Posted by Romulus View Post
    Are the shift maps no in FG? I haven't checked. But the B series has like 50+ added.
    Feb 2014
    Sydney
    295
    Used Defined Wideband? I use a custom setting which is set up for other tuning software with a Motec wideband which I also use in 2.24. Other than that it looks pretty good.
    Tune with actual data not simulated data!.....Applied Road/track Tuning
    Sep 2015
    44
    There are, but it would be good to know which map the trans is operating in e.g. performance, towing, cruise, normal
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Yortt View Post
    User defined inputs are already active in 2.25. If you have a specific wideband you want added, get in the Scanner thread and let Keith know. He's trying to add them natively to make it easier for users to share configs.
    Jaime
    Oct 2007
    Crawfordville, FL
    2,412
    TCM logging is something we are looking into. I don't have an ETA for it, but it is on my radar for sure.
    Eric Brooks
    HP Tuners, LLC
    Oct 2011
    QLD, Australia
    436
    Oh ok, my apologies, I realise what you mean now. Yes this would be great!
