I've been talking with a couple others over this. Basically I'm just not sure how to change the baro update parameters? 2.24 as I understand it would "cap" or "limit" the update parameters to where it wouldn't update while in boost with the 2bar or bigger OS upgrade. Haven't found where 2.25 gives any options for changing the baro parameters? I've got a problem right now with a Z28 updating the baro parameter while in boost and changing the baro to 105kpa. I think 105 is the "hard limit"? This wouldn't be too bad if the altitude I was tuning at was sea level, but at a normal 90 baro this changes the "background" fueling to where my fuel trims are going to -20 at idle only after getting into the boosted areas. Idle seems to be the most effected rpm area... Made VE tuning a pain until I finally figured out what was going on
I'm told efi will allow changing of this parameter, but from what I've read it looks like it doesn't always take? Does anyone know of a way to do this in HP?
Posting a stock tune file. The current tune does have the updated map parameters in it for the ls9 or zl1 map sensor...
