Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 77
Thread: 05 pre/post injection off
  1. #41
    Tuner 2007 5.9's Avatar
    Feb 2015
    Nor Cal
    93
    Have you logged Master Fuel Correction yet....
    That PID will tell you in short form which table is either currently limiting fuel or is getting ready to limit fuel.
    Les Szmidt
    Silver Bullet Tuning
    HP Tuners BETA Tester for 2003-2005 Cummins
    [email protected]
  2. #42
    Mar 2009
    45
    Ill give it a try in a few mins here. Working with the truck atm actually.
  3. #43
    Mar 2009
    45
    Getting boost P.F. when i log the master fuel correction.
  4. #44
    Feb 2015
    Nor Cal
    93
    That's a boost fuel limiter kicking in.
    The PF is "Protection Factor"
    Les Szmidt
    [email protected]
  5. #45
    Mar 2009
    45
    Can i simply disable that in the limiter table? Wanting to keep my wastegate shut anyway.
  6. #46
    Feb 2015
    Nor Cal
    93
    Quote Originally Posted by Blevins View Post
    That will disable your boost fuel table...so if you're using that for smoke control them you won't want to turn that off.
    Les Szmidt
    [email protected]
  7. #47
    Mar 2009
    45
    So what do i need to do to stop it from limiting my fuel rate? Adjusting my limiters down to 160mm3 from the max i had them set at has my load logging correctly now so thats a plus It will now measure the percent by how close the commanded rate is now. But im still dropping fuel rate. Got a high speed error on the last run when logging master fuel correction, but the truck broke the tires loose pretty bad went through a couple gears... Any suggestions?
  8. #48
    Dec 2015
    43
    Look at the RPM limit table. You are probably limiting fuel rate based on RPM.
  9. #49
    Mar 2009
    45
    RPM limit table is set to 159.986
  10. #50
    Feb 2015
    Nor Cal
    93
    Look into your rpm limiter tables...several in there in Stock form will begin to pull fuel around 2800
    Les Szmidt
    [email protected]
  11. #51
    Dec 2015
    Middleboro, MA
    142
    two logs attached. desired RP is correct.... and its shooting long enough... i just need to get the rail pressure up...
    https://www.dropbox.com/s/78grl1g32m...aved1.hpl?dl=0
    https://www.dropbox.com/s/o62js3p6fw...saved.hpl?dl=0
    Let me know your thoughts.
  12. #52
    Feb 2015
    Nor Cal
    93
    You are commanding 5500uS....
    With 5500uS, 3100rpm and 18* of main timing...your on the verge of melting something.
    You need to seriously stop what your doing and slow down with your changes.
    Les Szmidt
    [email protected]
  13. #53
    Quote Originally Posted by 2007 5.9 View Post
    I didn't stay at a holiday Inn Express last night but I agree 1000% with what Les has just said.
    Please take a step back from the keyboard.
  14. #54
    Dec 2015
    Middleboro, MA
    142
    Like i mentioned the duration doenst matter because it doesnt run anywhere near the volume its supposed to since i cant get the commanded fuel pressure to run correctly. If it was i wouldnt be at that long of a duration.
    Like i mentioned no smoke, no high EGT, no rattle... nothing... so by upping the PW its just running the same or less fuel pressure for longer but not getting the qty of fuel i need at all.
    Once i get help on the FP issue, ill halve the PW which should get me right around where i want to be.
  15. #55
    Feb 2015
    Nor Cal
    93
    Lower your pulse to a reasonable amount and your FPA will rise
    Les Szmidt
    [email protected]
  16. #56
    Dec 2015
    Middleboro, MA
    142
    it will because the truck isnt asking for as long of a duration. are you saying that its a diminishing return to go over that?
    If you look at saved1 it never gets over 17k psi... is there something also to make the FPR more aggressive?
    also stock is 2000us... are you saying that the max amount we should increase the 140 value is 1000us?
    also you guys dont sound like jerks i was thinking the same thing when i was tuning this.. if it ever did hit commanded fuel pressure it would put so much fuel in i agree it would melt the pistons..
    but i havent figured out yet how to get the rail pressure more agressive.
    editing again - Is it possible that the CP3 is the culprit since its not modified at all? i dont remember it being an issue with smarty at all before.....
  17. #57
    Dec 2015
    Middleboro, MA
    142
    update - new logs. Hitting 0x34 air density limits, but i thought i had the master protection piece off. guessing it is seperate and thats my problem?
    https://www.dropbox.com/s/xlh6gongjze477f/log4.hpl?dl=0
    https://www.dropbox.com/s/2m1bemypo3ben2h/log5.hpl?dl=0
  18. #58
    Mar 2009
    45
    Ive at this point maxed all the rpm fuel limiting tables out i can find to get it to read as high as 155mm3 but it still drops to about 138-140mm3 by shift point at 3200RPM...
  19. #59
    Automatic transmission? I don't have the software in front of me at the moment but I believe this is a limiter in the ecm that will defuel during shifts.
    William Collins
    04.5 Billet 48re-S366-DDP 90's-HP Tuners-Dual cp3.
    SDX 2011- 611/1091 Judgment Day 2011-641/1340 2.6 class Winner
  20. #60
    Mar 2009
    45
    Yeah its an auto. Im also having an issue when u go WOT at 65mph it goes to down shift and sets at 32-3300rpm and bucks. When i log main fuel correction its saying high speed govnr i also get the boost P.F.... Never noticed this new issue of the down shift until last night when i kicked it down on the hwy to do a log.
